gpiproxy.dll error in WinDVD 5
Moderator: lata
sfriedman39
When I first installed WinDVD 5 it was working. However something now has corrupted it. I keep getting a gpiproxy.dll error whenever it starts. Can anyone tell me how to fix this?
htchien
I guess you have turned the hardware support setting on after you run WinDVD 5, so when you run WinDVD next time it found your hardware is not compatible and keep crashing.
I would suggest you to remove the program, and open Registry Editor via Windows Task Bar->Start->Run, type regedit.exe in and then press Enter.
In the Registry Editor, delete the following folders:
My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\InterVideo\DVD5
My Computer\HKEY_CURRENT_USER\Software\InterVideo\DVD5
And then install WinDVD 5 again. This time don't turn on the hardware support in WinDVD.
If this does not work, contact Corel Tech Support for help.
Hope this helps.
Hope this helps.
Ted (H.T.)
