Copies of burned DVDs
Nick G
Post by Nick G »
Not sure whether I have missed something here but I have a question about making copies of a DVD disk that I have made with VS8.
If I try to copy the dvd in total with say NERO 6 (+others tried) the copying fails before the end although the resulting disk can be used in part - some sections missing/jumps etc.
Also, having created a disk image, burning a new copy with the Ulead disk image application creates a complete copy but I have noticed some skipping not evident in the original project burn - ie inferior copy.
Is this a common problem or likely to be something to do with my setup (which I know has not been detailed here) Any ideas?
thecoalman
Re: Copies of burned DVDs
Post by thecoalman »
It's probably the media, try some better discs. Burns are more likely to fail near the end than the beggining. Try keeping your projects below 4 gigs. You could also try a slower burn rate and make sure you have the latest updates for you software and the newest firmware for the drive.
