What format is your video clip in.
Avi / Mpeg 2 / Mpeg 1 / Wmv
You need to reduce the size of your video file to make it easier to view on the web.
Large files take a long time to load and your audience gets bored.
If you use .wmv files, these not only reduce the size but will play on a pc using windows media player.
If you are using VS 8 go to Share / Share Video on Line.
You have several options regarding size / quality. Test a few out to see which one is suitable.
You can always use windows media encoder to produce the same files.
Free download from:-
http://www.microsoft.com/windows/window ... fault.aspx
Hope this helps
