I realised that when I apply any transition and play the clip it stutters the first time, subsequently is plays normal. Then again if I change any transition parameter it stutters again returning back to normal playback speed till I change a parameter again.
What could be the reason and how it can be avoided.
Clip Stuttering
babdi
- motherboard: ASRock Extreme 11
- processor: Intel 3770K
- ram: 32 GB DDR3
- Video Card: Asus 660TI 2 GB
- sound_card: On board Realtek
- Hard_Drive_Capacity: 6.128 TB
- Monitor/Display Make & Model: 22",BenQ 2222 LCD HD 1920x1080
- Corel programs: Video studio
AlBunda
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
You have a good processor and a fair bit of ram, but 1.5g is an odd number, evening it up helps, so 1gb or 2 gb from even numbers of sticks when using more than 1, so 1, 2, 4 stick of ram is best.
Your graphics card is quite poor in todays standards, so improving that may help, or checking you have the latest drivers anyway for a start.
Using a seperate drive to the one the operating system on may also help.
What may be happening though is it's rendering and keeping a temp file fo the transition and when you change it, it needs to re-render it and then it's fine again.
babdi
- ram: 32 GB DDR3
Clip Stuttering
Thanks skier. Okay. To start with I need to even out RAM sticks ,2) I need to upgrade my Display card to say 512 MB, 3) My video files are on another drive ( 120 GB ), 4) My video card drivers are the latestskier-hughes wrote:You have a good processor and a fair bit of ram, but 1.5g is an odd number, evening it up helps, so 1gb or 2 gb from even numbers of sticks when using more than 1, so 1, 2, 4 stick of ram is best.
I also add that (as suggested by corel knowledge base) I increase my SWAP file size which set to MAX 4096 MB. I thought maybe that should help me a bit. I have changed the resampling quality to "good" from the default "better" in preferences.
I guess i need to fork out some quids to pep up things
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
HI babdi.... I did mention a few of these upgrade recommendations in a previous thread.
I could also be because your are working with mpeg4 files in uncommon variable frame rates in the same project.
If you have your project settings set to a standadrd frame rate the mis matching of frame rates could possibly be asking VS to work harder especially with transitions in between two clips with different frame rates.
skier-hughes
- Microsoft MVP
- ram: 4GB
You have too good a memory, I base each answeer given on the info supplied in that post. These items wiill surely add to the griefClevo wrote:HI babdi.... I did mention a few of these upgrade recommendations in a previous thread.
