Timeline view problem
marlar
Post by marlar »
Hello
I use the VS9.
When i put the zoom to max for the timeline view, i have just the first image of the clip, even whith the models given by Ulead.
What is the problem in my installation ?
Marlar
MrA
Re: Timeline view problem
Post by MrA »
marlar wrote:Hello
I use the VS9.
Marlar
In preferences, select thumbnail view.
marlar
Post by marlar »
Yes, but for long clip it is not easy.
But the question is : why i can't see each frame of the clip on the timeline view ?
At the beginning of the installation, it works correctly. Now it does'nt work. Why ?
Marlar
Post by Black Lab »
If you have it set to Thumbnail View you will (should) see each frame.
Thumbnail & Filename View will only show the first frame plus the filename.
Filename View will, of course, only show the filename.
marlar
Post by marlar »
It is the problem, i change it and the problem is solved.
Marlar
