Problems with Motion Backgrounds!!!
anakin
Post by anakin »
From years I use this marvelous Software... However' I had never realized that when a Motion Menu is used, the program rencoding the mpeg with consequent serious loss' of quality!'!!
Having now found this big beautiful defect, I am forced to address to other softwares, as already' am doing, with obvious loss of time!!!
Does someone of you have a solution???
P.s = Sorry for my bad english!!!
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
I've not noticed any serious loss of quality when I've used motion backgrounds.
What settings are you using for encoding?
DB83
Post by DB83 »
IRRC, motion menus are encoded according to whatever properties you set at the final stage.
So even if your titles are dvd-compliant, your menu's can be at a different data rate.
anakin
Post by anakin »
Thanks for the answers
For example: I put the same file as first play menu and title but the quality' it results different... How come?
The file is dvd compilant!!!
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
skier-hughes wrote:I've not noticed any serious loss of quality when I've used motion backgrounds.
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
DB83 wrote:IRRC, motion menus are encoded according to whatever properties you set at the final stage.
anakin
Post by anakin »
My settings are:
Resolution 720x576
Bitrate costant 8000
Frame rate 25000 frames/sec
Devil
Post by Devil »
Try a lower bitrate. You may be overloading the encoder with the multiple layers with buttons etc.
Vfreak
same problem
Post by Vfreak »
I realized the same problem.
footage on background of motionmenu have
a lower quality.
DVDWS always encodes menu, so I use high quality avi-files as input.
But after encoding the menu has a lower quality.
It seems like "removing fields effect", like a picture without
"anti aliasing". Understand? (my terrible english... ;o) )
You can see it, if the same video (video of motionbackground) is pasted on start of the title (to fade into the title, realized and encoded in videoediting software)
Picture of pre-encoded title is much better than motionbackground of menu. (high quality settings in DVDWS)
I have tried a lot, avi-files in different codecs, with DV or full resolution
(720x576, or 768x576) (I create PAL-DVDs)
Nothing changes....
Vfreak
Post by Vfreak »
some tests - same result.
Videofiles as motionbackground
looks like badly deinterlaced.
(try to create a short video including fine structures, text for example -
you will see the effect. Problem is not the encoding. I take the same file for menu and title, both are avi-files, both will be encoded by DVDWS.
Background of menu looks like deinterlaced, title is OK.
I tried every setting of fields, nothing changes.
(lower filed, upper field, progressive, 768x576, 720x576)
I don¡¬t like DVDWS2.0!!!
Every day a new problem and no resolution...
Good ideas for dvd-projects, but some doesn¡¬t work
with this software... (Quality of picture is most important for me)
This menu-quality-problem for example doesn¡¬t exist in DVDWS1.3!
I have tested it! (with the same source files)
Back to DVDWS2
... some unexpected:
take a still frame as menubackground.
(same properties like the video, some fine structures, text....)
Then create a motionbutton.
The whole menu will be rendered as mpeg-video.
Result?
High quality, the still frame is OK, no "deinterlace-look"
But it¡¬s also a motionmenu, with encoded mpegvideo!
What is different??
Vfreak
Post by Vfreak »
Want to know solution?
Footage for menubackground have to be progressive.
Any interlaced footage will be deinterlaced by DVDWS.
(with unbeautiful results)
lazael
Post by lazael »
Vfreak wrote:Want to know solution?
Mmm ... If it is, wonder if this could be the answer to fuzzy text ?
