Ok, first of all Video Studio 11 RULES! And sorry for stupid question
Now.. i have multiple separate vsp projects (files) but they are all intented for the same movie of mine. Is there a way that i can join this projects in VSP format when i want to create movie in the end and then export it to the dvd, because i want lose any quality doing something like that.. Or do i have to export each project to a clip on my hard drive and then import those clips in my final project
Joining projects
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
Although the advice by Clevo and Guy is correct, you can also add a VSP to the current VSP, by clicking the Insert Media Files into Timeline button (the folder icon above the timeline).
I must tell you, though, that I tried this once and was not happy with the quality of the nested VSP, so I resorted to the previous advice given.
Jeff
Dentler's Dog Training, LLC
dijego
thanx guys for quick responses, that helped me
indeed black lab, i inserted vsp to vsp and it works, although sometimes i get message file format missmatch and i asume it is becouse some project settings are not the same.. and i will see quality once i export it all to test dvd.. if the first solution is better, i will export each project to mpeg2 as said..
What format are the clips you are working with - MPEG2 or AVI?
Jeff
dijego
oh i figured it out.. the message file format mismatch is actually just that my dvd wasnt inserted, i mean the dvd that has source material for project such as pictures and clips
thanx again
well if you mean the clips that i use for project before i export the project to the final format, i use both mpg and avi clips, and wmv alsoBlack Lab wrote:What format are the clips you are working with - MPEG2 or AVI?
thanx again
Oh, ok. If they were all AVI then I was going to suggest rendering to a whole AVI file before inserting into your other project. Since they are mixed you will probably be better off rendering to MPEG-2, since that will be your final format.
You just want to render as few times as possible, especially when using lossy formats such as MPEG-2.
Jeff
