Video Studio v10 nicely writes IFOs, BUPs, and VOBs to DVD media but not to the HDD. When I re-autheor an existing DVD of a TV recording (IFO, BUP, VOB structure), I cannot use "Create Disk" as the video becomes too large, and no compression is available at that point; so I try the "Create Video File" option, writing to my HDD, thinking I can use DVDShrink later to burn the files onto a DVD disk. But all I get is a file with an MPG extension (won't play on a standard DVD player without the IFOs and VOBs). Re-authoring the MPG results in the same problem. Is there some way to get Video Studio to write to the HDD and create the VOB file structure like it can to DVD media? Maybe v11 has overcome this problem.
G-man
http://www.mednetconnection.com
Will VS Create VOBs on HD?
In the burn window choose Burn to DVD Folder instead of Burn to Disc.
Jeff
Dentler's Dog Training, LLC
FYI - There are only two things that affect file size: Playing time and (combied audio & video) bitrate. If you check the box that says Do Not Convert Compliant MPEGs, your project settings will be ignored (assuming you are using "ripped" DVD-compliant MPEGs) and the bitrate will be the same as the original file. Otherwise, the bitrate is determined by your project settings....the video becomes too large, and no compression is available at that point... Re-authoring the MPG results in the same problem.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
