VSP 11 - Hordes of trouble
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
An mpeg4 can come in many guises, and although VS may well work with some of them, it appears it will not work with yours.
If as you say the frame rate changes depending on lighting conditions, how do you expect VS to play back a 26.457 that then changes to 25 or 28 or 32 or 15 in the space of seconds?
You wanted a work around, I suggest you use what worked before, convert to a wmv file and use that. Content is obviously the key to your video rather than quality, which is fine, so the small amount of quality you lose by converting to wmv shouldn't really be noticeable.
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
This is a free converter listed in the other section of the forum which might help....
http://www.erightsoft.com/SUPER.html
babdi
motherboard: ASRock Extreme 11
processor: Intel 3770K
ram: 32 GB DDR3
Video Card: Asus 660TI 2 GB
sound_card: On board Realtek
Hard_Drive_Capacity: 6.128 TB
Monitor/Display Make & Model: 22",BenQ 2222 LCD HD 1920x1080
Corel programs: Video studio
VSP - Hordes of Problems
Post by babdi »
Thank you Clevo & Skier-Hughes
As said in my earlier post and I will convert to a WMV and work.
Now I have a question
I wish to change attributes of audio for all clips at a time. How do I do it
For example I wish to set the volume level to 50 for all clips or add auto level
video effect to all clips
Babdi
Clevo
ram: 4GB
Re: VSP - Hordes of Problems
Post by Clevo »
babdi wrote:Thank you Clevo & Skier-Hughes
Babdi
Can't think of a way doing that other than doing it manually.
Someone else might have some more nouse in this area
Just export the sound track from the [Share] tab as a WAV file.
Open it in Audacity (FREE Audio Editor) - adjust whatever you wish. Save as a new audio file and then import that into VideoStudio, replacing the existing audio track.
babdi
ram: 32 GB DDR3
Post by babdi »
Dear sjj1805
I think you missed my question
My question was a) How to change the volume of all clips at a time or b) how to apply say, a video filter like "Anti shake" to all the clips at a time.
Now we need to visit each clip to apply the effect or adjust the volume.
Cheers
Babdi
Clevo
ram: 4GB
Re: VSP 11 - Hordes of trouble
Post by Clevo »
babdi wrote:Dear sjj1805
My question was a) How change the volume of all clips at a time or b) how to apply say, a video filter like "Anti shake" to all the clips at a time.
Cheers
Babdi
I don't think it can be done in a batch.
babdi
ram: 32 GB DDR3
Post by babdi »
Clevo
IF what you say is affirmed then I think then my question should pass to "wishlist" :o
Clevo
ram: 4GB
Post by Clevo »
if that's what you wish for.... :)
I like the fiddly aspect of editing...
Not sure with how many clips you are working with but I'm fairly sure I saw in a tutorial somewhere you can copy and past the same filter onto each clip as quickly as clicking and pasting.
Post by Black Lab »
Steve understood you question, you just didn't understand his answer. To change the volume of all clips you need to go to Share > Create Audio File. This will create a wav file of all of your audio. You then re-insert that file and adjust the volume level, or add filters.
If you want to add the same video filter to all clips you would take the similar action of creating a video file of all your clips, then re-inserting to add the filter.
Another option is to add the VSP of your project into a new project where it is treated as one file, not individual clips, where you can add filters or adjust the volume. However, I have not been happy with the quality of the picture when doing this.
babdi
ram: 32 GB DDR3
Post by babdi »
Black Lab wrote:Steve understood you question, you just didn't understand his answer. To change the volume of all clips you need to go to Share > Create Audio File. This will create a wav file of all of your audio. You then re-insert that file and adjust the volume level, or add filters.
I dont understand as to why I should convert all files to a WAV format and then as you say adjust the volume again :-?. Are you saying converting all to WAV files will merge the audio of all clips into one continous track ?
Clevo
ram: 4GB
Post by Clevo »
Post by Black Lab »
Exactly.
