Placing audio on a slide show
Jabel
Is there a way to place as many songs on the dvd so you can have music in the background while showing all the photo,s that the disc will hold? Say 100 photo,s with about 5-10 seconds showing? I,m really a newby on this dvd creating an can,t find any thing in the book. Every time I add one song it drops the one before it.
JulienneMBA
I going to try to answer your question. You need to go to advanced audio section. They will have your pictures at the bottom and some folders to the left. Find your folder with your music you would like played. Hold down the control key and click the files of the music you would like. Drag the files to the beginning of your slideshow. Go to the little button that says (123). Here you can put the music in the order you would like. Press the key that says you would like your slideshow and music to match. In the right side there is some numbers that show how long each picture will show and how long the slideshow is. If your pictures are less than 3 seconds, I suggest adding another song. Then you can preview your slideshow with music in there. I hope I helped you.
