Nature of the problem
Cannot burn an image of a non-compywrited (i.e., home shot) DVD
Properties of your source files (format, file size, where did you get it?)
A home video (actually of a football game) DVD that was made using a camcorder hooked to some type of streaming recording device (I did not do it, but saw the setup) . Basically a camcorder using RCA type plugs to a recorder that burns a DVD directly
I can use Nero to successfully capture the image to disk, so I know it works.
What devices are involved and their mode of connection?
Philips DVD+-RW SDVD8820 AD15 (plugged into module bay on Dell Lattitude laptop)
Project Settings
Default for DVD Movie Factory 4.04
Output format (file, DVD, VCD, SVCD)
Trying to create an ISO from the disc
PAL or NTSC
NTSC
Error Codes (if any)
When I attempt the copy, I get the following pop-up/error:
Window Title: Ulead Copy.now
Window Text: The source disc cannot be copied. It requires on-the-fly copying.
Cannot copy DVD to image file
Not too sure what you are trying to do
If you mean rip your own DVD to the hard-drive, then for mf6 we use Import from DVD to HD ( new project > next > add media > import.. ).
If you mean copy a DVD as an image, the use nero, or ulead burn now ( new project > copy disc > select source + select destination > disc image file ).
Not too sure whether mf4 has the import function either
