I only watch a movie now and then but it has always installed and worked fine on my xp home laptop and desktop.
Recently bought a new dual core HP computer with Vista Premium and went to install this to use to watch movies, the install appeared to go ok yet at first I get a popup type warning that says
IVIVID~1
JPEG:
I hit ok and it opened the viewer window (figured ok fine no splash.jpg but at least the program seems to work), yet I get no typical menu bar to let me choose or set options for playback like I was used to on my xp based system.
Guessing this is some sort of Vista compatability issue? Wondered was there anything I can do upgrading wise or any adjustments I can try or make that might help fix this? I can right click on the screen and get some basic menu options but they are somewhat limited and harder to control via this method vs the standard control panel that I used to be able to access and use on the same program thru xp home (that menu bar seems to have dissapeared when I installed this same program on vista machine).
I know some may laugh at my older version here (I am many steps behind the current version and i realize this) but for now and then basic dvd playback I really liked this program and didn't feel it needed any improvements for my limited use.
Iwas just hoping if there is or was a way to use windvd4 in Vista Premium and still get my full menu bar and such (maybe a tweek or adjustment or nominal fee upgrade) then I would still continue to use it.
Bill
