VS 11
I have MOV files that i have added to a new project. I can play the MOV file in the timeline and sounds and looks good. BUT when i create a video file i hear all static the video is good..
if i try a MPG file it works fine just with the MOV file.
What settings do i need to get the audio to convert.. IU have tried different audio settings in the output file.
VS 11 add MOV to timeline create video file all STATIC
What???? To MPG from MOV? To MOV to MPG? MOV & MPG files mixed in one project?if i try a MPG file it works fine just with the MOV file.
Are you trying to make a new MOV file? What output format are you looking for?
You can try using SUPER (FREE!!!) to convert your audio/video to another format, or you can use SUPER to extract the audio from your MOV file into a WAV file. Then, you can use Video Studio to combine the old MOV video with the new WAV audio.
Changing the output usually wont help. When you have a problem converting a file from one format to another, it's usually a problem on the "from" side... For some unknown reason, it can't decode (de-compress) the original format properly, so it can't convert it "to" anything.What settings do i need to get the audio to convert.. I have tried different audio settings in the output file.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
