Error message on VS11
Blackbeagle
Hi folks-
I'm a newbie to VS11 so bare with me. I've captured my HD footage to my hard drive so now I have to edit/burn. I'm ready to 'share' now. So I set the output and now have to render. I do this before I go to bed because I know it's going to take hours. When I get up, I see the error message that says, "Unspecified Error [5:0:0]". Does anyone know what this is? It keeps doing this.
My specs are:
AMD Athlon 3400+
XP Pro
2.5 GIG ram
200gb hd
512mb video card
Thank you
My specs are:
AMD Athlon 3400+
XP Pro
2.5 GIG ram
200gb hd
512mb video card
Thank you
The question is, though, what did you 'share' to? We normally recommend you first produce a DVD-compatible mpeg-2 of your project by using Share > Create Video File > DVD.
Once you have your mpeg-2, save your project, then open a new one. Don't worry about a name for it -- the objective is just to clear the timeline.
Then you go to Share > Create Disc, and the burning module will now open. Insert your new mpeg-2 into the burning timeline, make your menu and burn. Also, make sure 'do not convert compliant mpeg files' is ticked in the middle of the three icons in the bottom left of the burning screen. You should not have to adjust any of the properties in the burn module.
The point is, though, that you should NOT have any video being rendered in the burning module -- only the menu itself needs to be converted to video.
Blackbeagle
OK..I need help here step by step. I have video clip on the 'clipboard'. I drag it down to the timeline, then I go to 'Share' and use drop-down button 'DVD/VCD/Mpeg, then choose another drop down button "NTSC Mpeg2". Then I save it to the folder I want, then it starts the process, but it's really slow. Am I doing this right so far? After it goes through the whole thing, then can I burn it?
Yes, you are doing the first step correctly and, yes, it will take a while. It is rendering your clip to a MPEG-2 file.
When it is finished you will go to File>New Project. You do this simply to clear the timeline. Then click on the Share tab and choose Create Disc. The burn window will open. You will then click on the Insert Media button will you will insert your newly created MPEG-2 file to burn.
Jeff
Dentler's Dog Training, LLC
Blackbeagle
One more stupid question-. When I'm creating the video file, why would I want Mpg 2? Why don't I want to burn at mpeg 4? Why not create something at HDV at 1080i? Also, will the final product I burn be in HD? After all the footage was in HD. the clip was only 20 minutes so that should fit into a 4.7g DVD.
Micker
I'm encountering a similar error
I've converted everything to MPEG-2
I've even tried to burn the sample files included in VS to test it.
The odd thing is that Adobe Premier Elements can burn the exact same files.
I've used the Nero Clean tools,
I've also uninstalled Adobe Premier Elements
It starts to think, for about 3 seconds and then up pops Unspecified error [5:0:0]
Any help will be greatly appreciated
Here is the info on the system I appologize I realize it's long but I am not sure what info would be helpful:
System Information
Time of this report: 9/18/2007, 18:17:03
Machine name: ALIEN_TEST01
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: ALIENWARE
System Model: M5700I-R2
BIOS: Ver 1.00PARTTBL
Processor: Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 740MB used, 3198MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Mobility Radeon X1800
Manufacturer: ATI Technologies Inc.
Chip type: ATI Mobility Radeon X1800 (0x7102)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_7102&SUBSYS_23421584&REV_00
Display Memory: 256.0 MB
Current Mode: 1920 x 1200 (32 bit) (60Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6601 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/10/2006 00:58:04, 256512 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 2/10/2006 00:57:46, 1502208 bytes
Device Identifier: {D7B71EE2-3242-11CF-FD6F-4803A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x7102
SubSys ID: 0x23421584
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0880&SUBSYS_08800000&REV_1008
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5345 (English)
WHQL Logo'd: Yes
Date and Size: 12/21/2006 16:26:00, 4405248 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio Input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x27C8
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 02:08:44, 57600 bytes
| Driver: usbd.sys, 8/4/2004 08:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 08:00:00, 52736 bytes
| Driver: kbdclass.sys, 8/4/2004 08:00:00, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 04:01:08, 40840 bytes
+ Synaptics PS/2 Port TouchPad
| Matching Device ID: *syn0802
| Upper Filters: SynTP
| Service: i8042prt
+ Logitech USB WheelMouse
| Vendor/Product ID: 0x046D, 0xC00C
| Matching Device ID: hid\vid_046d&pid_c00c
| Service: mouhid
| Driver: mouclass.sys, 8/4/2004 08:00:00, 23040 bytes
| Driver: mouhid.sys, 8/4/2004 08:00:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Motorola SM56 Data Fax Modem #2
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 171.1 GB
Total Space: 190.8 GB
File System: NTFS
Model: VIA 6421 RAID 0 SCSI Disk Device
Drive: D:
Model: Optiarc DVD RW AD-5540A
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 08:00:00, 49536 bytes
System Devices
Name: Intel(R) PRO/Wireless 3945ABG Network Connection
Device ID: PCI\VEN_8086&DEV_4222&SUBSYS_10008086&REV_02\4&2803E7C1&0&00E2
Driver: C:\WINDOWS\system32\DRIVERS\w39n51.sys, 10.01.0000.0013 (English), 12/5/2005 00:55:30, 1428096 bytes
Driver: C:\WINDOWS\system32\w39NCPA.dll, 10.01.0000.0032 (English), 11/28/2005 12:10:32, 483328 bytes
Driver: C:\WINDOWS\system32\w39MLRes.dll, 10.01.0000.0032 (English), 11/28/2005 12:11:08, 2600960 bytes
Name: Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_90821584&REV_02\3&B1BFB68&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 16:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/4/2004 01:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/4/2004 01:59:44, 95360 bytes
Name: Intel(R) 82801G (ICH7 Family) SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_90821584&REV_02\3&B1BFB68&0&FB
Driver: n/a
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_90821584&REV_02\3&B1BFB68&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 1/7/2005 20:07:18, 138752 bytes
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D4
Device ID: PCI\VEN_8086&DEV_27D4&SUBSYS_00000000&REV_02\3&B1BFB68&0&E2
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/4/2004 02:07:48, 68224 bytes
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D0
Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_00000000&REV_02\3&B1BFB68&0&E0
Name: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_90821584&REV_02\3&B1BFB68&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 02:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 02:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 03:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 02:08:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 08:00:00, 7168 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_90821584&REV_02\3&B1BFB68&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/4/2004 02:08:38, 20480 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_90821584&REV_02\3&B1BFB68&0&EA
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_90821584&REV_02\3&B1BFB68&0&E9
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_90821584&REV_02\3&B1BFB68&0&E8
Name: Intel(R) 82801GBM/GHM (ICH7-M Family) Serial ATA Storage Controller - 27C4
Device ID: PCI\VEN_8086&DEV_27C4&SUBSYS_90821584&REV_02\3&B1BFB68&0&FA
Name: Intel(R) 82801GBM (ICH7-M) LPC Interface Controller - 27B9
Device ID: PCI\VEN_8086&DEV_27B9&SUBSYS_00000000&REV_02\3&B1BFB68&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 16:58:02, 35840 bytes
Name: Mobile Intel(R) 945GM/PM/GMS/940GML and Intel(R) 945GT Express PCI Express Root Port - 27A1
Device ID: PCI\VEN_8086&DEV_27A1&SUBSYS_00000000&REV_03\3&B1BFB68&0&08
Name: Mobile Intel(R) 945GM/PM/GMS/940GML and Intel(R) 945GT Express Processor to DRAM Controller - 27A0
Device ID: PCI\VEN_8086&DEV_27A0&SUBSYS_00000000&REV_03\3&B1BFB68&0&00
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 2448
Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_00000000&REV_E2\3&B1BFB68&0&F0
Name: VIA VT6421 RAID Controller
Device ID: PCI\VEN_1106&DEV_3249&SUBSYS_90821584&REV_50\4&6B16D5B&0&38F0
Driver: C:\WINDOWS\system32\DRIVERS\viamraid.sys, 5.01.2600.0430 (English), 4/8/2005 08:43:26, 60928 bytes
Name: Realtek RTL8169/8110 Family Gigabit Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8169&SUBSYS_97101584&REV_10\4&6B16D5B&0&28F0
Driver: C:\WINDOWS\system32\DRIVERS\Rtnicxp.sys, 5.635.0923.2005 (English), 9/30/2005 14:11:42, 78720 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_70001584&REV_00\4&6B16D5B&0&20F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 08:00:00, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 08:00:00, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 08:00:00, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 08:00:00, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 09:46:40, 6400 bytes
Name: ATI Mobility Radeon X1800
Device ID: PCI\VEN_1002&DEV_7102&SUBSYS_23421584&REV_00\4&31B7BFB9&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6601 (English), 2/10/2006 00:57:46, 1502208 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0005 (English), 2/10/2006 00:26:38, 40960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 2/10/2006 02:01:38, 27232 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativckxx.vp, 10/14/2005 13:10:12, 58560 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 1/18/2006 13:57:44, 929 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 1/18/2006 13:57:42, 1114674 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6601 (English), 2/10/2006 00:58:04, 256512 bytes
Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0310 (English), 2/10/2006 00:22:42, 258048 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 2/10/2006 00:53:04, 26112 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0384 (English), 2/10/2006 00:44:42, 2636096 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0001.0090 (English), 2/10/2006 00:39:24, 860352 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dat, 1/13/2006 16:48:10, 114630 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 2/10/2006 00:51:26, 53248 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 2/10/2006 00:27:14, 17408 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 14:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4129 (English), 2/10/2006 00:51:48, 405504 bytes
Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4129 (English), 2/10/2006 00:52:50, 61440 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2498 (English), 2/10/2006 00:53:20, 114688 bytes
Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0015 (English), 2/10/2006 00:53:10, 77824 bytes
Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2500 (English), 2/10/2006 00:53:00, 40960 bytes
Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0034 (English), 2/10/2006 00:27:48, 151552 bytes
Driver: C:\WINDOWS\system32\ATIDEMGR.dll, 1.02.2231.38684 (English), 2/10/2006 00:29:30, 282624 bytes
Driver: C:\WINDOWS\system32\atifglpf.xml, 12/2/2005 16:20:30, 6005 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.5695 (English), 2/10/2006 00:27:00, 5124096 bytes
Driver: C:\WINDOWS\system32\atioglx1.dll, 6.14.0010.1050 (English), 2/10/2006 00:30:56, 6684672 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4004 (English), 2/10/2006 01:03:44, 307200 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/4/2004 08:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 08:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/4/2004 08:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/4/2004 08:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 82432 bytes
system.dll: 1.01.4322.2032 English Final Retail 4/20/2007 12:08:52 1224704 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 9/18/2007 12:40:56 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 9/18/2007 12:40:54 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 9/18/2007 12:40:54 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 9/18/2007 12:40:55 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 9/18/2007 12:40:55 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 9/18/2007 12:40:55 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 9/18/2007 12:40:55 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 9/18/2007 12:40:55 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 9/18/2007 12:40:55 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 9/18/2007 12:40:56 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 9/18/2007 12:40:56 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 9/18/2007 12:40:56 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 9/18/2007 12:40:56 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 9/18/2007 12:40:56 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 9/18/2007 12:40:56 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 9/18/2007 12:40:56 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 9/18/2007 12:40:56 223232 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 08:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 08:00:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 08:00:00 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 08:00:00 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 20480 bytes
qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 13:44:28 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 733696 bytes
quartz.dll: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 1287680 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 08:00:00 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 08:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 08:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 08:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 08:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 08:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 08:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 08:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 08:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/4/2004 01:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 08:00:00 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 08:00:00 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Ulead DV Writer,0x00200000,1,0,ulDvRite.ax,1.00.0000.0005
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
ATI MPEG Audio Decoder,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
ATI EZShare Server,0x00200000,1,0,atidvcr.dll,9.12.0000.51204
Ulead IEEE Push Source Filter,0x00200000,0,1,ulIEEEPushSource.ax,1.00.0000.0010
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
Audio Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
DV V/A Source Filter,0x00400000,0,1,dvsf.ax,7.00.0000.0000
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
Ulead DVD Navigator,0x00000000,0,0,UleadDVDNavigator.ax,1.00.0002.0001
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
ATI EZShare Client,0x00200000,0,1,atidvcr.dll,9.12.0000.51204
ATI Time Shift Splitter,0x00600000,1,2,atidvcr.dll,9.12.0000.51204
ATI Time Shift Reader,0x00600000,0,1,atidvcr.dll,9.12.0000.51204
ATI MPEG File Writer,0x00200000,1,0,atidvcr.dll,9.12.0000.51204
ATI MPEG Video Decoder,0x005fffff,1,2,atidvcr.dll,9.12.0000.51204
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
DV V/A ACM Source Filter,0x00400000,0,1,dvsf.ax,7.00.0000.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
ATI VCR Video Converter,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
DV Video Source Filter,0x00400000,0,1,dvsf.ax,7.00.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
ATI Video Format Converter,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2180
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Disk Record Queue,0x00200000,1,1,wmedque.dll,9.00.0000.2980
ATI CC Multiplexer,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
Color Converter,0x00200000,1,1,declrds.ax,9.00.0000.2980
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ATI MPEG Audio Encoder,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
ATI VCR Stream Sink,0x00200000,0,0,atidvcr.dll,9.12.0000.51204
Ulead DV Scene Detect,0x00200000,1,1,ulDvScDt.ax,1.00.0000.0019
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
SmartSound Soundtrack,0x00400000,0,1,DirectQX.dll,3.00.0005.0000
SmartSound SDS Reader,0x00400000,0,1,SDSReader.dll,3.00.0005.0000
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
ATI MPEG Video Encoder,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
ATI MPEG Multiplexer,0x00200000,2,1,atidvcr.dll,9.12.0000.51204
Ulead DVD Video decoder 2,0x00400000,2,2,ulDVDVideo.ax,2.00.0000.0033
ATI Audio Delay Filter,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Dib Output,0x00200000,0,1,DibOutput.ax,8.00.0000.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Dib Receive,0x00200000,1,0,DibReceive.AX,8.00.0000.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
ATI Video Scaler Filter,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
ULead Infinite Pin Tee,0x00200000,1,1,UInfTee.ax,1.00.0000.0010
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Ulead MPEG-4 Encoder,0x00200000,2,0,ulmp4enc.ax,1.00.0002.0001
Ulead MPEG-4 Splitter,0x00600000,1,3,ulspmp4.ax,1.00.0004.0005
Ulead MPEG-4 Audio Decoder,0x00400000,1,1,uladmp4.ax,2.00.0001.0005
Ulead MPEG-4 Video Decoder,0x00400000,1,1,ulvdmp4.ax,2.00.0001.0006
Ulead AMR Audio Decoder,0x00800000,1,1,uladamr.ax,2.00.0000.0009
Ulead MPEG-4 ASP Video Decoder,0x00400000,1,1,ulaspvdmp4.ax,1.00.0001.0002
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
ATI CC Splitter Filter,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
Ulead DVD Audio decoder 2,0x00200001,1,1,ulDVDAudio.ax,2.00.0000.0057
ATI Still Capture Filter,0x00200000,1,0,atidvcr.dll,9.12.0000.51204
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Screen Capture filter,0x00200000,0,1,wmesrcwp.dll,9.00.0000.2980
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
ATI Noise Reduction Filter,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
ATI Audio Pitch Correction Filter,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
Ulead MPEG Splitter,0x00400002,1,2,ulspmpeg.ax,1.00.0000.0124
Ulead MPEG Audio Decoder,0x00400000,1,1,ulDVDAudio.ax,2.00.0000.0057
Ulead MPEG Video Decoder,0x00400000,1,1,uldsmpeg.ax,1.00.0000.0079
Ulead MPEG Encoder,0x00200000,3,1,ulesmpeg.ax,1.00.0002.0054
Ulead MPEG Audio Encoder,0x00200000,1,1,uleampeg.ax,1.00.0000.0022
Ulead MPEG Muxer,0x00200000,5,1,ulmxmpeg.ax,1.00.0001.0160
Ulead LPCM Audio Encoder,0x00200000,1,1,ulpcmpeg.ax,1.00.0000.0007
ULead File Source (Async.),0x00400000,0,1,ulasync.ax,1.00.0000.0013
Ulead H264 Decoder,0x00200000,1,0,uldsh264.ax,1.00.0000.0008
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Video Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980
ATI Video Rotation Filter,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Ulead Mp3 Decoder,0x00400000,1,1,uldamp3.ax,1.00.0000.0002
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Ulead Audio Dual Channel Filter,0x00200000,1,1,UAudioDCFilter.ax,1.00.0000.0002
ATI VCR Stream Source,0x00600000,0,0,atidvcr.dll,9.12.0000.51204
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2180
ATI FM-On-Demand Filter,0x00200000,1,1,atidvcr.dll,9.12.0000.51204
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2180
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
TechSmith Screen Capture Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
DV Audio -- NTSC,0x00200000,1,1,quartz.dll,6.05.2600.2180
DV Audio -- PAL,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Audio Layer3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming Capture Devices:
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,2,1,,5.03.2600.2180
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.2180
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming System Devices:
Realtek HD Audio Input,0x00200000,3,1,,5.03.2600.2180
Realtek HD Audio output,0x00200000,10,1,,5.03.2600.2180
System Information
Memory: 2046MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
Monitor Max Res:
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x1002
Device ID: 0x7102
Revision ID: 0x0000
Revision ID: 0x0000
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
PS/2 Devices
| Service: i8042prt
| Service: TermDD
| Service: i8042prt
| Service: mouhid
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
File System: NTFS
Drive: D:
System Devices
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
,0x00000000,0,0,,
BDA CP/CA Filters:
Audio Renderers:
Blackbeagle
I am curious as to why you would use VS when you have Adobe Elements. I heard that it is a much better video editor.Micker wrote:I'm encountering a similar error
System Information
Memory: 2046MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
Monitor Max Res:
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x1002
Device ID: 0x7102
Revision ID: 0x0000
Revision ID: 0x0000
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
PS/2 Devices
| Service: i8042prt
| Service: TermDD
| Service: i8042prt
| Service: mouhid
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
File System: NTFS
Drive: D:
System Devices
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
,0x00000000,0,0,,
BDA CP/CA Filters:
Audio Renderers:
LaurieC
I'm having the same error code problem. WHen I go to share and create disc the rendering begins for 2-8 seconds then the Undefined Error [5.0.0]
I have a new computer with XP/SP2.
Intel Duo Core/2 Processor 2.33
2 gig RAM
3 Hard Drives=250 gig/120 gig/120 gig
Samsung DVD writer
I just upgraded from VS8 to VS11. VS 8 worked perfectly on my old computer.
The Samsung DVD Burner works perfectly with my media when buring DVD's from Roxio.
Also, with VS11 when sharing a mpg or any other type of file to the computer it works perfectly.
Your help is appreciated. Thanks.
2 gig RAM
Samsung DVD writer
Blackbeagle
I finally got mine to work after numerous Error messages. Here's a quick description of what I did.
1. Capture video
2. Drag thumbnail to timeline.
3. Create Video File
4. Select type of files from drop down menu
5. Save to whatever folder on your PC
6. Let it render
7. File>new project
8. Share
9. Create Disc
10. Add video file
11. Burn
It worked for me the last few times without seeing the error message.
1. Capture video
6. Let it render
7. File>new project
8. Share
9. Create Disc
10. Add video file
11. Burn
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
That's it!Blackbeagle wrote:I finally got mine to work after numerous Error messages. Here's a quick description of what I did.
1. Capture video
6. Let it render
7. File>new project
8. Share
9. Create Disc
10. Add video file
11. Burn
