Cannot capture HDV video
heinza
Post by heinza »
my first experience with studio 11+ is disappointing. my camcorder is Canon HV20. When I set the Firewire-output to DV, everything is ok. But when I set the output to HDV, then the program will recognize the camcorder being in HDV mode, but will not start capturing. The following error message appears:
" Cannot switch capture mode. Please check, if your video capture driver functions correctly [15023:4:2]"
Where is my video capture driver and how can I check the driver?
The video was done in HDV, of course. I'm working with my notebook nx6125 from HP.
Any ideas?
Thanks for including your System details. I think a lot of the problems you are experiencing may have to do with your computer. Others will undoubtedly have other views, but in my humble opinion it just may not be up to the job of capturing Hi Def video. Your 512 MB of RAM is very much on the low side for this, and unless you have an external hard drive connected, your 40 GB of hard disk space is barely acceptable for SD DV capture, particularly if it has a few other things on it apart from XP, let alone HDV.
heinza
Post by heinza »
Ken Berry wrote:Thanks for including your System details. I think a lot of the problems you are experiencing may have to do with your computer. Others will undoubtedly have other views, but in my humble opinion it just may not be up to the job of capturing Hi Def video. Your 512 MB of RAM is very much on the low side for this, and unless you have an external hard drive connected, your 40 GB of hard disk space is barely acceptable for SD DV capture, particularly if it has a few other things on it apart from XP, let alone HDV.
Hi Ken,
you're right, that I'm working on the low side, so I've added another 512 MB of RAM, and capturing will go to an 80 GB external HD. But this didn't solve the problem. And of course I did SEARCH first...: my notebook has got an integrated ATI X200 graphics device, and I've read all the posts dealing with the ATI graphics, that seem to be not supported by Corel. Plus I cannot change the capture plugin: IVI Capture Component is the only one on the list. Moreover Corel advertises, that with their SMART PROXY technology even notebooks can do the HDV job. So in my humble opinion we now should discuss the real problem: will there be new capture plugins available, that support ATI graphics?
I've got two additional PCs and might be able to change to a NVIDIA graphics card: which one is recommended, i.e. is guaranteed to work?
etech6355
Post by etech6355 »
I use an ATI X1650 in a P4 2.8Ghz macihine. Captures HDV using VS11+ trial without any problems.
I wonder if you have installed the latest directx update from June. You must install this update for VS11+ to work properly. If you haven't done so install this Directx 9.0c update. It adds enhancements to previous Directx 9.0c distros. VS11+ does not operate properly without this latest June update installed.
wai2
Post by wai2 »
How about if I use Vista Ultimate? As my understanding, Vista is preinstalled DirectX 10. But I still got that error message, and even I'm using NVIDIA GeForce 8600 GTS. Any idea to fix the problem? Thanks.
etech6355
Post by etech6355 »
I have the GeForce 8600GTS installed on Vista Home Premium. Very fast video card, I don't have access to the Nvideo NView program for customizing desktops. Do you know if it's not function for Vista yet?
I don't know why you can't capture in VS11+. Can you capture using Movie Maker?
tyamada
Post by tyamada »
You didn't mention if you have Windows XP Service Pack 2 installed? You cannot capture HDV without it.
wai2
Post by wai2 »
etech6355 wrote:I have the GeForce 8600GTS installed on Vista Home Premium. Very fast video card, I don't have access to the Nvideo NView program for customizing desktops. Do you know if it's not function for Vista yet?
The case is same as heniza. While I'm capturing the video with HDV (SOny HDR-HC3), it pop up a error messge " Cannot switch capture mode. Please check, if your video capture driver functions correctly [15023:4:2]", and then all the items became dimmed.
However, when I turned on the iLink Conversion to be DV on the HDV, VS11+ ran perfectly. And it also ran prefectly when I use Movie Maker and Nero Vision. Seems like the capture drive can't recognize my HDV, but I only found one choice "IVI Capture Component" under the "Change Capture Plug-in".
What's the problem actually?
heinza
Post by heinza »
I'm afraid, that you are exactly right, wai2!. I've been using video editing software since 1998 on an Apple MAC and on two PCs from different suppliers, and in my opinion VS11+ still is fatally erroneous. To prove this statement today I've installed Premiere 3.0 (Tryout) on my simple notebook. They don't really recommend such low end PCs, but hey it worked perfectly! I could capture HDV footage from my HV20 and after editing I could save my 3min30sec project back to my HV20 in HDV quality.
A notebook is not my editing solution, but when you're traveling you've got no choice. I often do pre-editing and then I don't care about:
- no smooth preview
- no realtime effects
But I do care about a shuttle preview and that I can use my pre-edits in my final project. BTW, transcoding 3min30sec and saving to tape took 22 min with my 1.8 GHz CPU.
At this time I'll have to say goodbye to VS11+. Maybe we'll meet again, when some improvements have been made.
etech6355
Post by etech6355 »
heinza,
The ulead products convert the HDV stream to PS (Program Stream) so I'm not to sure how your laptop would perform doing this conversion on-the-fly.
Premiere 3.0 (Tryout) must be capturing in TS (transport stream), which is the natvie format of the tape, so that's why it could write back to tape in a short time. The ulead software converts the PS on the timeline back to TS before exporting back to tape, that does take time.
The benefit of PS over TS using ulead is how it smart-renders cuts or joins. The program is the fastest, I don't think the TS can be smart-rendered fast like PS video can be.
I hope that soon ulead releases a patch to fix some issues with VS11+.
I have to comment though that I have installed VS11+ trial on a few of my XP machines, everyone of them has no problem capturing from my HC3 highdef camcorder. Very smooth previewing & capturing. The problems I've been having in VS11+ is working with TS stream video. In previous versions of VS if you loaded TS stream video then the software would convert it to PS for editing, that was removed in VS11+. Sometimes VS11+ picks up the correct fielding of my TS highdef files and most of the time it doesn't. So when I load a TS stream video and output it as PS the video is basically frame_based. I don't have an answer for this. But, capturing in PS format, editing and outputing all PS format the program works pretty nice.
wai2
Post by wai2 »
Below is the exact response from Corel Customer Support Services, and agreed this is a bug and required for applying the patch. But did anyone know when will the patch be released?
Thank you very much for the valuable informations you have given. I have
reported this issue to Corel Engineering. It will need to be resolved in a
service pack release to correct the problem.
Due to the new capture plug-in that the current version is using, there are few
incompatibility issues regarding certain capture devices. Until then, if you
have another capture utility or previous versions of VideoStudio, please use it
to capture your video. Once captured, you can bring it into VideoStudio 11 plus
for editing.
Please visit the following links from time to time to keep updated with the
latest released patches for Corel Products:
http://www.ulead.com/download/download.htm
http://www.corel.com/servlet/Satellite/ ... 4926747575
I have also forwarded this issue on to the Technical Support Supervisor. We
appreciate you taking the time to share your insight as a customer and we look
forward to improving our service to you in the future.
wai2
Post by wai2 »
It's really too bad that there is no any schedule for the newer patch release.
Thank you for contacting Corel Customer Support Services. As of now, there are no official date when the patch would be released for VideoStudio 11. We have to wait for the patch until 4th quarter of this year and have to visit our website frequently to know more about the latest released patches for Corel Products.
wai2
Post by wai2 »
Do anyone know the exact release date for this kind of patch?
I'm wondering why I have to wait for such a long period for fixing this bug!!
You know as much as we do. No one here is a Corel/Ulead employee, and quite a few of us have been waiting, with decreasing patience, virtually since the release of VS11, for the patch. I personally find it both inexplicable and totally unacceptable that such major flaws in a new product are taking more than 5 months, and more likely 8 or 9, to fix by what is, after all, a major software conglomerate... :roll: :cry:
wai2
Post by wai2 »
Did anyone tried to escalate the problem to the CEO of Corel?
I encounted a problem with Adobe Arcabat Professional 8.1, and tried to found any solution on their user forum. I found that I was also not alone with this problem, and also found that there were many people tried to send the complaint letter to the CEO of Adobe. Then the problem got repsonse very fast, through the patch is still being proceed. But Adode is very positively to support that problem.
