I have Cool 3D ver 3.0 and when I render the video, I can't choose any other codecs to use. As I also work with Canopus Let's Edit, I need to be able to access that codec as well. Any ideas?
Braham
Using other codecs
thecoalman
The AVI codecs are available after you select create vide> AVI, click the options button, then the AVI tab and select your codec under the compression pull down box.
I'm not familiar with let's edit or what it requires but if it requires a video using the canopus DV codec selecting either DV1 or DV2 should work. Also if you absolutley need to convert it to a DV-AVI with the canopus codec they have a DV converter on their site.
My guess is it should work with a regular AVI using no compression.
bray1
