I tried the demo version of Studio 11 Plus in English. Could not load in French. Then I uploaded the demo from Corel France. It is in French but it only burn DVD in PAL.
Is it possible to get Studio 11 PLUS in French in Canada with NTSC format?
IS STUDIO 11 PLUS AVAILABLE IN FRENCH
I don't know, but I would have thought that the French version from France would be like the English version regardless of whether it is sold in the UK, Australia or North America. In the initial installation process, you are asked what TV system you want to install for, and/or the country where you will be using the program. If you say NTSC or Canada, (or first select Canada, then also select NTSC), then VS will be set up to operate in the NTSC standard regardless of the language used.
In the English language version, you can in any case change the TV standard between PAL and NTSC in the burning module in the first (Settings and Options) icon in the bottom left of the burning screen.
- ram: 2 GB
- sound_card: Intel GMA 950
Yes.
All versions of VideoStudio are capable of NTSC / PAL but you have to set the default format at the time of installation. Despite setting the default format you can still manually alter your project settings to the other but only for that session. The next time you open VideoStudio it will revert to your chosen default format.
