Question about UFO format - lossy/lossless?
DavidGreensmith
Post by DavidGreensmith »
I've done some searches through the ULEAD documentation, these boards and Google trying to figure out whether UFO is lossy (e.g. JPG) or lossless (e.g. PNG, BMP).
The only explanations I can find say that the base objects are stored separately, but not whether raster data are compressed and if so whether they are compressed using lossy or lossless algorithms.
The reason I ask is that I want to ensure that the degradation I experience on the image is minimised. When using Paintshop Pro, I would save as a bitmap whilst editing and then finalise as JPG. I've been saving my PI projects as UFOs, but want to know whether I'm losing information (as you would with successive JPG saves).
Does anyone here know?
Thanks,
David
carpe diem, quam minimum credula postero
(Horace 65-27 BC - trans = Just do it and stuff the consequences!)
Bobm03
Re: Question about UFO format - lossy/lossless?
Post by Bobm03 »
DavidGreensmith wrote:~~~ I've been saving my PI projects as UFOs, but want to know whether I'm losing information (as you would with successive JPG saves).
Thanks,
David
When you save your UFO file, open the Options dialog, you have three compression choices: None, RLE (a form of lossless compression) and JPG. Use JPG only if you want to make a smaller file. Note that in the "Advanced" button, there is a choice for saving either the vector data or the image data as you wish.
So, select "None" and you're not going to loose any information.
heinz-oz
Post by heinz-oz »
I second that
DavidGreensmith
Thanks for the information. RLE seems to be set by default, which is fine with me because it's lossless.
David.
