ripple editing/all pictures/titles? VS11+
brucefl
- motherboard: I7 3770
- processor: 3-4 Gig
- ram: 12gb
- Video Card: NT Geoforce 640
- Hard_Drive_Capacity: 2 T
- Corel programs: VS21 VS18thru21 and more PIX13
I have to chance the duration of my clips to a longer time. In ripple editing according the the book you can move clips around and the titles will move with it?
In trying to make the clips longer, I click ripple, then select all the clips, but under clip, it is grayed out, unless I unclick the ripple.
I assume you can not to this, and the only alternative is to, lengthen the clips then moving each title manually?
thanks Bruce
VS11 +
thanks Bruce
VS11 +
I am a little confused. As far as I have been aware, if the clip is a video clip, you cannot make a clip longer, only shorter by chopping a bit off it. The only clips that can be extended are either still photos, colour panels (and of course, transitions between clips)...
The only way of making a video clip longer is by adding an extra clip (when ripple editing should work) and then rendering to a new video file...
- ram: 2 GB
- sound_card: Intel GMA 950
You can lengthen video clips by adjusting the playback speed (slow motion).
Please view the following links:
Playback speed
Ripple Editing
Playback speed
Ripple Editing
brucefl
- ram: 12gb
still clips
Sorry guys, my fault.
These are several still clips (pictures) I can lengthen the time by selecting all the clips, then going to clip, and changing the time.
In ripple editing you can move the clips around and the titles will go with you. What I need to do is (was) extend the time of each clip (which I do by clip), when I do that the titles are out of time.
Is there any way to select all titles with the clips when adjusted.
I know I can select all the title clips and move them at once, but where they are timmed differently, they don't line up with the correct picture, so moving them the equiv. of the adjusted time clip doesn't work. Trying to find an easier way then to move one title at a time.
- ram: 2 GB
Please view:
Ripple Editing
Ripple Editing
Clevo
- motherboard: Asus PK5
- processor: Intel Quad CPU Q6600 2.40GHz
- ram: 4GB
- Video Card: NVIDIA GeForce 8600 GTS
- sound_card: Auzentech X-Fi Forte
- Hard_Drive_Capacity: 850GB
Bruce,
Click the ripple editing button, then also click on the all the tracks you want to include with the ripple editing. The symbol is a little "chain link" at the front of each track. It will keep sync'd
I found a problem when I include the music track in that it throws ripple editing into a dilemma. I'll report more on this when I do some experiments to confirm things.
brucefl
- ram: 12gb
ripple,doesn't work with clip duration?
I click on the ripple editing, it turns to gold?
Then I click each chain, turns to gold,
then I highlight the pictures, click on clip
but it is grayed out?
Apparently you can not change the clip duration in
ripple editing?
I will review the link sjj1805 provided. I do get the upgrade disc, this way I get the book also, will have see if the link or the book says anything.
thanks Bruce
ripple editing?
thanks Bruce
Clevo
- ram: 4GB
Ripple editing simply allows you to add more clips or adjust stills in a time line without ruining the sycn of the clips after it in a timeline.
It doesn;t make individual clips longer but obviously it would make the project longer if you add more in.
Without distorting the speed of the clip the only way to make a video clip longer is to import the original from the camera tape and re-cut it longer.
Are you trying to fill space on a music track?
brucefl
- ram: 12gb
still clips
Hello,
These are still clips. I added them, then started titling each one, after looking at it, I figured it needed to be longer so I was trying to add time to it,, and at the same time, keep the labels (in the title line) lined up with the individual pictures.
I can select all the clips and add time, trying to keep the titles sequenced right
