MF 6+ Stuck at 16:9
Gra
MF 6+ Stuck at 16:9
Post by Gra »
Hi guys
I bought MF 6+ last week and have just authored my first project, which was made in MSP. I created the final MSP video file as MPEG 2 4:3 and opened it in MF6 with MPEG 2 4:3 project settings but after I burned the disc it plays as 16:9. I've tried a couple of different discs and tried out putting the settings as PAL DVD but it still stays stuck as 16:9. Anyone had this before or can anyone offer any advice?
Thanks & regards.
Gra
MSP8 (SP1), VS8, C3DPS, MF6+, DAZ Studio, Poser 6, Nero 6, Audacity, Photoshop 7.0
You can see a couple of my movies at [url]http://www.youtube.com/glaustin[/url]
etech6355
Post by etech6355 »
What are your project settings set to in MF6+ (GEAR Icon)
Did MF6+ re-render this video?
Gra
Post by Gra »
Hi & thanks
I didn't notice it re-endering. My settings are:
MSP8 video file
MPEG files
24 bits, 720 x 576, 25 fps
Frame-based
(MPEG-2), 4:3
Video data rate: Variable (Max. 6000 kbps)
Audio data rate: 224 kbps
MF6+
MPEG files
Lower Field First
(DVD-PAL), 4:3
Video data rate: Variable (Max. 7000 kbps)
Audio data rate: 256 kbps
(When I get to the burn screen there's actual an icon at the bottom also saying 4:3)
Would it be better to set both to output PAL DVD? Also, since my mesage, another irritating problem has arisen. When I playbackon the stand alone DVD player every 30/40 seconds or so the audio goes dead for a split second.
Any advice would be most welcome.
Thanks & regards.
Gra
Gra
Post by Gra »
PS
the version I downloaded last week is 6.00.0194.1. Do I need any patches or anything or is this the latest version???
Thanks & regards.
Gra
etech6355
Post by etech6355 »
You should install this patch, the top one.
http://www.ulead.com/tech/dmf/dmf_ftp.htm
Please post back if this link is working for you.
If it doesn't work then goto this thread and download the file that Steve posted listed down a few posts:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=25732
After you install this patch it's not going to fix your exact problem. Fixes MF6+ and is a nice update.
What you should try to do is put the file into the MF6+ timeline, trim it down to about 2-5 secs's. Then goto "Export Media" -> FAST EXPORT.
This will take about 2 seconds to make a small clip of the file (a sample of it's properties).
Then email me this small test clip. Every second is equal to about 1 meg so a 4 second clip=approx 4megs so this should be easy to send.
