Hardware: HP Pavilion M7467, D940 pent 3.2 g dual core, 2048 ram, 300 hd
Software: XP Media Ctr, SP2, w/ VideoStudio 8.00.0100 SE DVD
Video source: Olympus SP320 ("Motion-JPEG format", 640x480, 15 or 30 fps)
Forgot what I recorded at, but looks like 640x480 and displaying at 15 fps during edit, edit mode set to NTSC 29.97 MPEG 24 bit, 720x480, DVD-NTSC, lower frame first, quality setting 70, data rate constant 6000.
Filetype from camera .mov, and output filetype will be MPEG from VS. I have 18 clips totaling ~ 6 minutes with cross fade transitions. When I play them (Instant p/b or HQ), I have a few dropped frames, either 2 or 4 frames together.
Incrementing with the 'NEXT' key, it moves at 30 fps, but each pair are the same (actual 15 fps). I have 2 dropped frames at 8:09 & :10 (mid pt 1st clip), then I have 2 washed out appearing frames during a transition at 24:07 & :08, then 2 more instances of 2 blank frames, one instance of 4 blank frames, and 1 final instance of 2 blanks at less than sequence mid point. The rest of the sequence is OK.
I was wondering why dropped frames, since it's just a copy operation from the camera memory chip. The drops are not in the original clips.
Also, if there's no way to avoid a few white flashes, is there a way within this program to edit them out? Or a downloadable utility to do the same?
I admit I have a lot to learn, but happy that the technology is where it's at today. I plan on updating my camera and software soon, but need to get this short documentary done for a friend that needs it ASAP! (no, it's not porn ... )
At this point I'm on the learning end, but have done some work in stage lighting and sound, and some studio audio recording. I guess you could say I'm angled in the direction of camera work as well as pre and post production, since when I go to a flick, I focus heavily on camera angles, framing, lighting, as well as scene editing, continuity, sound rendering, etc.
Even at age 66 I plan on working up to some commercial efforts regarding the 'origins' question, so wish me luck, and thanx in advance for any tips.
This looks like a great forum, and I'll be sure to contribute when able.
Lee Bowman
http://westlabmultimedia.com/
