Preview changes when AVI created
mark@chateaudelacouronne
Post by mark@chateaudelacouronne »
Hi All -
I'm using MSPro 7.
I've created a 4 minute movie with jpeg images to background music.
On preview, the timings are perfect between music and images.
On creating a video file (I've tried AVI, MPEG and QT), the images lag behind the soundtrack by about 5 seconds.
I did put a 5 second delay in the audio track to compensate, which is fine for the first couple of minutes. However, as soon as it reaches one of the cuts in the soundtarack, it seems to catch up, and it all goes off sync again.
I've not has this problem on any other similar projects I've done on the same PC and with MS pro7.
I'm pretty sure my system should be able to cope with what is a relatively small project like this. I've tried reducing all the jpegs to minimum size in case I was asking too much of my PC, but it has no effect whatsoever.
May be a bit of a dunce, but I'm stuck now.
Any ideas?
Devil
Post by Devil »
If your sound track is mp3, I suggest you try converting it to WAV before you bring it into the timeline. I recommend Audacity for this.
heinz-oz
Post by heinz-oz »
Did you patch MSP 7 with SP 3? You will have to be the judge if your system is in fact well capable of doing what you want because we know nothing about it :wink:
I had sound sync problems in the past with MSP 6.5 and 7, later fixed by putting a PCI sound card in rather than using the onboard AC97 sound.
preview changes after creating AVI
Thanks for these. I'll try converting to WAV and give it another go.
SP3 is installed
Sorry for not including details of my system - I thought it would come up as I included this info during registration.
AMD 64x2 d/c 4400+
NVidia GeForce 9700GT
2 x 160gB HDD striped, 1 x 160gB HDD sys, 1 x 160gB Data
2gB RAM
Soun Blaster Audigy 4 sound card
Devil - you really are a very clever man. I'm so impressed.
I've converted the soundtrack to WAV, and the timeline and edit points now remain exactly the same between the preview and the created AVI.
I could have saved a day of shouting at my monitor, throwing things around the office and generally being unpleasant to everyone and everything if I'd only have asked for your advice yesterday.
Thank you very much indeed. I would take my hat off to you if I hadn't stamped on it and torn it to pieces in frustration yesterday.
All resolved.
Kindest regards
Devil
Post by Devil »
Je t'en prie !
