Converting tp mpeg4 using Divx in MF5
ruggy1
Post by ruggy1 »
I have been away for a while, but have searched the topics before I post. I found a great tutorial by Steve (sjj805) relating to the use of Divx and VS10 to produce a Youtube template, which I have implemented. But I cannot find a way to do this in MF5. Does anyone know how to do this? Thanks
MF2, MF3, MF4, MF5, VS7, VS10+, VS12, Nero Vision Express. Ricoh and Sony 16x DVD recorder, Sony HC5 High def camera. Also Canopus ADVC110 for AV/DV input through firewire
etech6355
Post by etech6355 »
It's the same method as VS.
Export -> Custom. Select AVI -> Options and change the compression in the dropdown box.
One thing though, MF installs divx 5.1 I believe and puts the divx.dll file in the MF5 directory. If you bought & installed Divx 6.xxx Pro you may have to rename or move the file Divx.dll file in the MF directory in order for MF to pickup, see & use the other version that you may have purchased & installed.
ruggy1
Post by ruggy1 »
Thanks very much
