"L" Edit - I think
MikeB51
motherboard: Foxconn - A75M
processor: AMD A4-3300 APU X2
Video Card: ATI Radeon HD 4800 Series
sound_card: High Definition Audio Device
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Samsung SyncMaster 23 vis
"L" Edit - I think
Post by MikeB51 »
Hi Team.
I think what I want to do is called an "L" Edit (at least in Pinnacle Studio it was). What I want to do is keep the original sound track but use some different angle video clips. Would I be correct in saying that this is where I have to separate the video and audio files, and if I do, does it affect the sync at all?
Thank you and kind regards,
Mike.
Post by Trevor Andrew »
You should not have to ¡¥Split Audio¡¦
Use the overlay track for your angled video.
If this video has its own audio¡Xcut the main track at the angled video start and end frames. Mute the main video.
If the angled video audio is not to be used then you will have to sync the two accurately.
Aha L cuts and J cuts!!
Yes you can do those with VideoStudio and there is more than one way to do so. Here are two methods submitted by our forum members:
VS 9: J-cuts and L-cuts
MikeB51
Thank you.
Post by MikeB51 »
Hi Guys.
Thank you very much once again, I would be lost without this forum.
Kind regards,
Mike.
MikeB51
Syncing
Post by MikeB51 »
When it comes to doing this, would you be able to point me at any tips for getting the sync right please.
Mike.
Post by Black Lab »
The video clip that contains the audio you want to use must remain intact, or else you will have sync issues. You want to put the alternate angles on the overlay tracks, leaving the main track alone (video and audio).
Read these threads regarding Multi-Camera Editing.
