To Pan and Zoom without causing image distortion
Mike Warren
- motherboard: E7600 3.06 GHz 3.07 GHz
- processor: Intel Core 2 Duo CPU
- ram: 3.46 G Ram
- Video Card: Built into motherboard
- sound_card: Sound blaster Extreme X
- Hard_Drive_Capacity: 1250 G
- Monitor/Display Make & Model: Hanns.G, HDMI
When I save a still image from my video and then place it on timeline in Studio 10, I find I cannot use Pan and Zoom without it stretching wide the image, distorting it. This leaves me with only two choices - select "resampling option" for correct aspect ratio or fit to project, or select zoom and have my image distorted. It will not give both. But... I need to use zoom on many images I saved from my video. Is there an answer to this?
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
With your image selected in the timeline you will see two tabs under the library - Image and Attribute. On the Attribute tab is the Distort Clip box. Check that. Now right click on your clip in the Preview Window. You will now have other options: Keep Aspect Ration, Default Size, Original Size, Fit to Screen. Play around with those settings and see if any work for you.
Jeff
Dentler's Dog Training, LLC
