VS10+ stops pass-thru capture from VCR after four minutes
David Badger
Post by David Badger »
In the past I've transfered video from VCR by recording it first to my JVC miniDV videocamera then capturing the video from the JVC using the firewire connection directly into VS10+.
It made sense to take advantage of the pass-thru feature of the JVC and it all seems to work fine except that after VS has been capturing for 4 mins 38 secs it stops the capture. The JVC has no miniDV tape in it (if it does have a tape in, VS captures the tape content instead of the pass-thru from the VCR).
My guess is that VS is reacting to a signal similar to that which puts the JVC in standby mode after several minutes when in record mode but not actually recording. However even after VS stops the capture, the video from the VCR continues to play on the JVC's screen as well as in VS. How can I persuade VS not to give up capturing after 4 mins?
The JVC is model GR-DV900AA
David
jparnold
motherboard: Gigabyte Z390 UD
ram: 16GB DDR3
Post by jparnold »
Hi David,
Could you please give some more information about your PC such as operating system, hard disk size and free space, file system used (eg NTFS, FAT32 etc), etc etc.
John a
etech6355
Post by etech6355 »
I would try changing the settings under "Preferences" that affects capturing ( F6 Hotkey ).
Press "OK" to capture = ON (checked)
Stop DV tape when catpruing stops = OFF (unchecked)
