I have then done the following (copied from another one of my posts answered by Ron and Ken)
go to the Share>Create Video File step, and choose NTSC (or PAL, depending on where you're located) DVD. This will render your project to a DVD Compliant MPEG2 video file. DVD(SD) specs require that the video files be in the MPEG2 format, not DV or AVI. This step may take several hours, depending on the complexity of your project and your computer.
Did this bit fine and now have a MPEG2 file on my PC of 1.5GB ( lots of photos).
Next I did the following (again copied from another one of my posts answered by Ron and Ken)
Next I did thisOnce your DVD Compliant MPEG2 file is completed, go to the File menu and select New Project. This will clear the timeline. Do Not place anything in the timeline. Go back to the Share Step, and this time select Create Disk. This will open the Burn Module.
I now have a bunch of files in, like this, VIDEO_TS (3 OF) VTS_01_1 VTS_01_1 and VTS_01_2 but I do not know what to do with them. I assume I copy them to a DVD and that will give me a DVD that will play on my TV, is that so? Could someone give me the process to follow through in Ulead to do this please?Now insert the DVD Compliant MPEG2 you just created. Continue on building your menus, adding chapters ect., until the final step, which is where you burn the disk, Create DVD Folders, or a Disk Image file. Since you have Nero, you can at this point uncheck the Burn to Disk option, and check the Create DVD Folders. This is what's commonly called burning to your Hard Drive.
Also I want to add a folder to the DVD that contains the original pictures in their originbal format, to be able to access them on a PC. If I understand right from previous post I will find this facility at the burn stage under options.
Can this still be done if I am just copying these files to a DVD now that I have done a "burn to harddrive" first, as advised above? Or am I going about this bit wrong?
Any help would be appreciated.
