the sound in the laptop not working
abody_143
Post by abody_143 »
i installed the new ulead videostudio 11
when i worked in this program the video is working clear but the audio not working in my laptop
Why?
the sound is worrk in windows xp
Post by Trevor Andrew »
First check the properties of your pc¡¦s master volume control.
(loud speaker icon lower right of desktop.)
Or (Start-All programs-accessories-entertainment)
Check that ¡¥Wave¡¦ is not muted.
abody_143
Still not working
Post by abody_143 »
i have usb Hybrid Tv Tuner i installed in my laptop
the software with this device is ArcSoft TotalMedia
in this software the video and audio working clear
because the audio device in this software use "Audio Pin Source"
in Ulead Video studio i can't found any audio device just video device is working
Check the Windows Control Panel part of this link:
No Sound
abody_143
Still .............!
Post by abody_143 »
Nothing is working
Just The video device is working
No audio
i do what you say
but still
and thanks for help
Can I just double check
1. You DO have sound in Windows and other applications such as Windows Media Player.
2. You do NOT have sound when using VideoStudio.
abody_143
Still .........!
Post by abody_143 »
yes and clear nothing wrong with it
yes , the sound not working just the video
Re: Still not working
abody_143 wrote:i have usb Hybrid Tv Tuner i installed in my laptop
Have you tried Video from a source other than your TV Tuner.
I am trying to narrow down the problem to see if it is VideoStudio as a whole or just something related to the TV card.
If you don't have other video clips you could try downloading something small off the internet.
This link is fairly small: VideoStudio 9 Introduction 1:14 minutes / 7.5MB
If you have sound using a different source file then it seems to be a capture problem.
Did your TV card come with its own capture software?
If so try capturing with that and then import the video into VideoStudio.
Please let me know the results.
abody_143
Post by abody_143 »
when i play this file than you give me
it's work with videostudio with sound clear
also work with other media clear
i thank the problem in the device is the audio device
because the software with the tv tuner used "audio pin source"
in videostudio the device of audio say "Pass through to sound card"
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
I'd opt for capturing wth the tuner card's app, but....
Can you connect an output from the tv tuner to the line in of the sound card?
abody_143
Still
Post by abody_143 »
see
i will tall you something
i connect the receiver with usb tv tuner that "AV Wires" the video work
but the sound not work
thank for help
Am I right in thinking you have got this:
http://www.arcsoft.com/products/totalmedia/
ArcSoft TotalMedia™ 3 is a media hub that combines TV, video recording, photo editing, and media conversion in one easy-to-use program! You can watch and record TV shows (requires a compatible TV tuner card), edit photos or video, listen to music, rip CDs to MP3 and much more. It¡¦s everything you need packed in one versatile and easy-to-use application!
High-Definition Video
Enjoy the experience of playing high-definition (HD) MPEG-2 and WMV-HD files.
According to the above from their website your Arcsoft Total media should be able to record the TV shows. You can then import the Video File into VideoStudio. Have you tried to do that?
