WMV for Soccer/Football
JamesU2002
Post by JamesU2002 »
Can anyone recommend some WMV settings for Soccer/Football. Something that doesn't suffer from slow down when there is a lot of action on screen, some WMV export settings suffer from this.
I'm looking for around 4mb a minute in file size. 16:9 resolution.
Thanks guys and gals.
DVDDoug
Moderator
Post by DVDDoug »
I suspect it's going to be tough with so much compression.
I don't work with WMV files enough, so I can't give you the "correct" bitrate. A higher bitrate will give you better quality and bigger files. Video compression is "lossy'. Data is thrown-away during the compression process. More compression means more data is being thrown away.
If it was MPEG-2 (DVD) I'd say you need 40mB per minute or more, but WMV is supposed to be more efficient than MPEG-2.
The quality depends on 3 things:
- The resolution (i.e. 480x720)
- The compression method (MPEG-1, MPEG-2, WMV, etc.)
- The bitrate (kbps)
The file size (in any format) depends on the bitrate and the playing time.
DVDdoug wrote:Higher bitrate = higher quality = bigger file size = lower compression = less playing time.
Lower bitrate = lower quality = smaller file size = higher compression = more playing time.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
JamesU2002
It's a Web video thats why I need it so small.
Any WMV experts?
