Re-Link Problem IN VS8
dskaff
You picked a bad weekend to relocate your clips.
The daylight saving time fix was made to cure a relink problem after the clocks changed by one hour.
The clocks in England altered last weekend, the US this coming weekend.
Read the various postings re:-daylight savings patch.
Where are you in this world, if the US wait until next week to relink your clips, otherwise you may have to do it all again.
As you have moved your files yourself it is difficult to say if you’re a casualty of the daylight time bug.
So how many clips are you talking about?
dskaff
dskaff
Not exactly. I click on File/Open Project. Then it asks to Re-Link. I click that and it wants me to find the file. When I went to it after the move, it linked and said some clips were lost (or something to that affect). I moved the mpg files back to the original location and repeated File/Open Project. Now it doesn't see them at all.
If you are only looking at 15 clips, why dont you start a new project and then import your clips to the time-line.
If you have edited the clips then that info will be lost and you will have to re-edit
Watch out for the daylight savings bug this weekend.
sorry if this is not much help, just a bad time of year.
All the Best
All the Best
dskaff
As you are working on a project at the moment, Create a Video File of your project, this will make a copy of your edited project saving all your work into one file.
Should the daylight saving time bug affect you , at least you have a copy of your edited work.
The 'time thing' will only effect the projects running now.
Any new projects will be ok untill the Fall, when your clocks go back one hour, assuming the problem is not fixed. ( its a long time to wait)
Its time for bed its about 11pm
