Still image from Widescreen Video
ralphtrent
Hello
I have shot a 16:9 video. I wanted to make a still image from a clip. when I do this, VS squeezes the still to 4:3 ratio. is there a way to get around this to either, one leave it as a wide screen image, or 2 custom trim the sides of the 16:9?
Ralph
Ralph
Please check this one from Corel:
"Download the uvMPEG2.dll file from our FTP address: ftp://userdl:guest@ftpph.ulead.com/down ... vMPEG2.dll
If you get an error message, click OK, then right-click on the page/window and select 'Login As..' then enter the username and password. Replace the file (uvMPEG2.dll) in C:\Program Files\Ulead Systems\Ulead VideoStudio 9.0"
ralphtrent
Re: Still image from Widescreen Video
Thanks for the post, I am using VS11+ not 9. Also, what is this dll? Is there any information on corel's site about this dll?asjr_4584 wrote:Please check this one from Corel:
Thanks,
Ralph
ralphtrent
uvMPEG2.dll is a component of Ulead Photo Explorer. This solves the problem of switching to 4:3 (with letter box included) even when already set to the 16:9 mode. Back-up first your existing uvMPEG2.dll then try to use this new dll from Ulead and see if it will work. It should be located under C:\Program Files\Ulead Systems\Ulead VideoStudio 11.Thanks for the post, I am using VS11+ not 9. Also, what is this dll? Is there any information on corel's site about this dll?
Do you mean when i do this????????????????????????ralphtrent wrote:When I do that the image is saved with lines through it and it's black and white. Any way to save it as i see it?
Switch to ¡¥project playback¡¦
Use Tools-Save Current Frame as Image
Will save what you see on the preview window
For 16:9 this will be 1024 x 576
ralphtrent
Hi Ralph
I do not understand why you are seeing a B/W image with lines.
When you use Clip (save as still image) or ¡¥Save as Still Image¡¦ from the panel icon you will get the original video size. 720 x 576.
If you are working with widescreen you need to use the Project and ¡¥Tools-Save Current Frame as Image¡¦ your image will be 1024 x 576.
As a work-round.
Distort the captured image.
Using the coloured captured image, use the ¡¥distort¡¦ function from the Attributes tab.
I still do not understand why the Tools option does not work.
What are the properties of the video file????????????
As a work-round.
ralphtrent
asjr_4584, I tried this last night. It looks like it will do what I wanted it to do, but this dll, also messed up my VS. What I mean is mt2 file can no longer been viewed in the program. When I go to import my AVCHD files off a dvd, it does not play them. they do not even show up as a regonized file type. Any other idea's?asjr_4584 wrote:uvMPEG2.dll is a component of Ulead Photo Explorer. This solves the problem of switching to 4:3 (with letter box included) even when already set to the 16:9 mode. Back-up first your existing uvMPEG2.dll then try to use this new dll from Ulead and see if it will work. It should be located under C:\Program Files\Ulead Systems\Ulead VideoStudio 11.
