How to extract audio track from an mpg file?
ppost
Post by ppost »
I'm using VS9. I want to extract a portion of the audio track from an mpg file. I plan to use this audio extract to overlay the audio track in a video. Can this be done with VS9? If not, can someone suggest another program that can? Thanks
Pete
lancecarr
motherboard: eMachines ET1861
ram: 12GB
Video Card: ATI Radeon HD 5400 Series
Hard_Drive_Capacity: 700GB
Post by lancecarr »
Just place the MPEG in the timeline. Then go to Share and Create Sound File. Select (and remember) where you want it to go and you will get a wav file of the track.
You can then use Audacity to edit the file. Audacity is free and can be found by a quick search on the internet. Altenately if you have any Nero suite on the computer like me you can use Nero Wave editor.
Post by Trevor Andrew »
To add
Once you have made the Wav file, add it to a project, you can edit/cut the file in the same way as cutting a video.
You can trim the ends using the yellow trim bars.
Use the whole clip or portions anywhere you like.
ppost
Post by ppost »
This is just what I needed.
