VS 9 won't eject disk after DVD Complete
toad
Post by toad »
I need some help please.
Everything seems to be working fine in VS9. After Completeing Creating DVD I get that it is 100% complete.
Problem- disk won't eject. The Program seems to hang up. The drive still continues to run even when you do a control Alt Delete to end program.
I've had to resort to shuting down computer in order to get disk out.
Disk plays on DVD player just fine.
Anyone have any suggestions as to what I should try to do to correct problem?
alanball
motherboard: Gigabyte Technology B450M H
processor: AMD Ryzen 5 3600 6-Core
ram: 16 GB
Video Card: NVIDIA GeForce GTX 1660 SUPER
Hard_Drive_Capacity: 2TB+480SSD
Monitor/Display Make & Model: ASUS VN247
Corel programs: VS10, VS2018 Ultimate, VS2021 Ultimate
Post by alanball »
Hi Toad,
I am having the same problem with VS10, but the program does not always lock up, but I find I can't eject the DVD disk on completion and have to restart the computer before I can eject it.
I find it also happens some times in the editing stage if I import music from a CD, and find I can't eject the CD.
Alan Ball
alanball
ram: 16 GB
Post by alanball »
Hi Guy's
Any bright ideas out there??????
Alan Ball
robruiz
Post by robruiz »
Have you tried burning using other application? does the problem occurs on other programs that uses the disc drive?
I Rip. I Burn. I Conquer.
alanball
ram: 16 GB
Post by alanball »
Hi robruiz,
thanks for reply, I do use Sonic to burn disks without any trouble, and not had a problem with any other program as far as reading or playing, only VS10 locks the disk drive up.
Alan Ball
robruiz
Post by robruiz »
Hmmm... I was thinking a SATA DVD burner issue, but since you said that it works fine with other programs... i dropped the idea and left me with nothing. :?
one last question, do you wait until 10 secs before you hit ctrl+alt+del? some drives, for some unknown reason, even with super capable system, still lags for about 10 seconds - 20 seconds -- this usually happens with Plextor SATA.
lancecarr
motherboard: eMachines ET1861
ram: 12GB
Video Card: ATI Radeon HD 5400 Series
Hard_Drive_Capacity: 700GB
Post by lancecarr »
Another possiblity is that the Sonic software, on installation, has decided it is to be the king of the DVD drive.
This especially occurs if you have their "Drag to Disc/ Drive Letter Access" feature enabled in the system tray.
Most times it results in an inability for other programs to access the drive at all.
It may be worth a try to disable this feature in the system tray whenever you are using another program that needs to access the DVD drive.
Post by Trevor Andrew »
On occasions this has happened to me.
I start Power Dvd or Nero and hit the eject button there.
Saves re-booting the pc.
toad
disk lock up
Post by toad »
Just read your post. I'm not having any trouble with the drive in other programs either.
Still lost as to what's going on.
I've waited as long as 2 minutes before hitting ctrl+alt+del and still nothing.
Thanks for the idea hate having to re-boot.
alanball
ram: 16 GB
Post by alanball »
Thanks trevor and lancecarr
for those ideas, I will follow them up next time I'm in VS
Regards
Alan Ball
toad
Big Thanks
Post by toad »
I want to thak Lancecarr for his suggestion to disable the drop and drag.
It fixed my problem thank you so much, I was really getting frustrated with the whole thing.
Take care
Toad
