MOV in VS10 = oke But VS11 crashes..
Marten
Post by Marten »
I now have both VS10+ and VS11+ installed. VS10 works great with mov (and quicktimealt147.exe. It solved all my mov-problem!) but VS11+ crashes as soon as I click on a mov/file.
Does anyone have an idea to solve it? Strange that all works well in VS10..VS11 should be even better or am I wrong?
best regards
Post by Black Lab »
From the Vista patch for VS v10:
When you have downloaded and installed this patch, your copy of Ulead® VideoStudio® will be certified as ¡§Works With Vista™¡¨
This patch is 42 MB in size and should take about 15 minutes to download.
The patch will not work on PCs that do not have Windows Vista installed.
You will be required to sign in (register) before downloading the patch.
NOTEs:
Windows Vista and the Windows logo are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries
This Update Pack is for Ulead® VideoStudio® 10/10 Plus (BOX, ESD, UPG, and activated TBYB) version.
This Update Pack cannot be uninstalled.
Since Video for Windows (VFW) is not supported in Vista, VFW codecs such as Indeo, Cinepak are not supported in Vista. The video content files provided by VideoStudio will now be encoded using .WMV instead of Indeo codecs.
Some 3D transition effects that won¡¦t be supported on Vista are removed from current release, including: Flying Board, Flying Cube, Flying Flip, Flying Fold, and Folding Box. Some templates under "Album", "Flash Light" and "Mask" transition effect are also not supported.
WDM devices are not supported by Vista. Thus, not supported by VideoStudio.
WMV and MPEG 4 format CAPTURE is not supported.
MOV and MPEG 4 formats are not supported in this version.
WinDVD 7, PocketDV show, and Cool3D are not supported.
Marten
Post by Marten »
Thank you for your reply, but I'm running Xp and "The patch will not work on PCs that do not have Windows Vista installed"....
asjr_4584
Post by asjr_4584 »
Try downloading the following file and save/overwrite it to C:\program files\Ulead Systems\Ulead VideoStudio 11\vio: ftp://userdl:guest@ftpph.ulead.com/uvqt.vio
Make sure VS is not running before applying the patch.
