Using VS 10 (or trying to) - When i try to launch it i get an error saying the program cannot start my resolution must be 1024 x 768 or higher. Mine is set at 1280 x 720. Whats the deal? My tv will only run on the 1280 x 720 res. What can I do to get this working?? Thanks, jme
Edit: OS is Windows MCE 2005
VS will not start - resolution issue
Re: VS will not start - resolution issue
What vid card are you using? Maybe fill out the system info in your profile will help.jme733k9 wrote:Using VS 10 (or trying to) - When i try to launch it i get an error saying the program cannot start my resolution must be 1024 x 768 or higher. Mine is set at 1280 x 720. Whats the deal? My tv will only run on the 1280 x 720 res. What can I do to get this working?? Thanks, jme
Just the vague info you are providing, tells me it's a video problem. But, thats just an assumption.
Have you tried setting the resolution to 1024x768? (not just higher)
A lot of vid cards have some really strange NxN settings.. Meaning, not a real standard, just a convenience for the user.
jme733k9
