Hello,
I search all the forum for my problem,but nothing....
Everithing ok on step 1 and 2...add movies,editing menus....
I start step 3 and the program freeze...about 10% or 45%...when is trying to "Converting video of the title...[001/003] "
I try burn a dvd,create a dvd folder,create a disc image....nothing....the same result...
2-3 days ago I made a dvd ....but now dosen't want to work enymore...I uninstall the program...install again....nothing....
PLEASE HELP
Step 3/3 freezing about 10% or 45%
This kind of problem us usually caused by a bad video file. It can be hard to tell, because a "bad" audio/video file will often play back OK, but cause trouble when you try to edit it, convert it, or make a DVD from it. (The various highly-compressed the file formats cause the most trouble.)
What format are your video files? Where did they come from? If you are using any still images or audio files, we need to know about those too. The Read This First post at the top of the forum tells you what we need to know in order to help you.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Mr.Symbol
Hello,DVDDoug wrote:This kind of problem us usually caused by a bad video file. It can be hard to tell, because a "bad" audio/video file will often play back OK, but cause trouble when you try to edit it, convert it, or make a DVD from it. (The various highly-compressed the file formats cause the most trouble.)
Thanks for your reply.
The files are .mpg and are comming from my DV Samsung camcorder.
I use only this files and the things from the program.
I had imported this files with DVDMF6....
Please...I need some help...what can I do?
Maibe only one scene is bad...how can I see this?How can i found the bad video file?
Thank you.
If This is a DV camcorder (that uses MiniDV tapes) you are in luck!
- Capture to AVI/DV via Firewire. This will transfer and re-package the DV data without altering or compressing it. (AVI/DV files are 13GB per hour.)
- Do all of your editing in AVI/DV format.
- Let Movie Factory will automatically do the MPEG-2 compression (required for DVD) when it creates the DVD.
No time to think.
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Mr.Symbol
SorryDVDDoug wrote:The files are .mpg and are comming from my DV Samsung camcorder.Grrrrr! MPEG files!
It is a dvd camcorder...this model: http://www.pixmania.co.uk/uk/uk/571932/ ... order.html....
So...how can I do it right...to transfer all the dvd...in my laptop and edit with DVDMF?
Thank you
Mr.Symbol
And....Mr.Symbol wrote:SorryDVDDoug wrote:The files are .mpg and are comming from my DV Samsung camcorder.Grrrrr! MPEG files!
Thank you
