"Capture from device" opens blank window
jcb2354
Post by jcb2354 »
I am using DMF 6 and the Hauppauge PVR-150 tuner card(which seems to be working fine). When I try to import video either from the launcher or from within DMF I get the "Capture Video" window coming up, but it remains blank. As an experiment I hooked up my Panasonic DV camera to the firewire and the computer recognized it but I still got the blank screen with the capture video.
Unfortunatly I upgraded both the computer and DMF from 5 to 6 at the same time so I don't know which could be the problem.
I tried reinstalling DMF but recieved an error of "could not find Moviefactory 6.msi" file and the setup program shut down.
Using Hauppauge WinTV PVR-150 tuner card
asjr_4584
Post by asjr_4584 »
Try to perform a clean removal of the program from your system. Here¡¦s a post from Corel website:
1. Remove MovieFactory 6 in the Add/remove programs;
2. After removing the program, go to this location and delete all folders: "C:\Program Files\Ulead Systems\Ulead DVD MovieFactory 6.0" "C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead DVD MovieFactory\6.0" "C:\Documents and Settings\[YOUR USERNAME]\Application Data\Ulead Systems\Ulead DVD MovieFactory\6.0" "C:\Program Files\Common Files\Ulead Systems\DVD";
3. Click on "START > RUN" and type in REGEDIT and press enter (you may not find the following keys after uninstalling the software but just to be sure, check them);
4. Locate the following registry keys and delete them by "right-click > delete". HKEY_LOCAL_MACHINE\SOFTWARE\Ulead Systems\Ulead DVD MovieFactory\6.0 HKEY_CURRENT_USER\Software\Ulead Systems\Ulead DVD MovieFactory\6.0;
5. Once deleted, restart the computer and reinstall the product.
Note: Note: Editing the registry could cause system-wide problems if critical keys are removed. Make sure you delete only what is mentioned and if you are not sure how to do this, skip this part.
Also, try to install the latest drivers for your Win TV-PVR-150. Here¡¦s the link: http://www.hauppauge.com/pages/support/ ... vr150.html
