I have used Adobe Premiere Pro 1.5 to export a video project to M2V and WAV files. I was then planning on importing the video into MovieFactory, using it to create a menu system and chapters etc and then burn to dvd.
I opened up MovieFactory and created a new project. In the "Add Media" screen I imported the M2V clip ok. The problem is that MovieFactory hasn't detected the WAV file of the same name nor can I find any way of manually importing the audio file to run parallel with the audio-less m2v file.
Any help on getting the audio running would be greatly appreciated.
Importing a m2v/wav export from Premiere
From the ¡§Select source and import (Step: 1/3)¡¨ window, click the ¡§Edit Room¡K¡¨ Right click on the Storyboard/Timeline view panel and select ¡§Import Audio >> to Music Track¡¨. From here, you can add your WAV file in the Storyboard/Timeline panel and run it in parallel with your m2v video clip. You can also directly add your WAV file by selecting the ¡§Music Tab¡¨ of ¡§Edit Room and click ¡§Add Audio¡¨.
