When I started using VS 10 plus in Dec 06 my DVD menus were behaving differently then they are now. For example, I create separate VSP projects then open a new project and insert two to four projects into the new project. The resultant DVDs would return to the DVD main menu after each title finished playing and I could then choose the next title to watch. The last two DVDs that I created with only two titles on each automatically transition from the first title into the second title with no pause or return to the DVD main menu. I have looked around the forum and other helps but can not find out what settings got changed or what is causing this. When there are multiple titles on a DVD I want it to return to the main menu after each title plays. What have I inadvertently changed, how can I fix this?
Thank you for your kind attention.
Keith
DVD Menu Question
In the Burn module (Share>Create Disc), press the gear looking icon, found in the lower left. This opens the Project Settings Dialog. At the bottom there is a section labeled Navigation Control. If the option "Auto Repeat when clip..." is checked, uncheck it, and then in the Clip Playback, click the drop-down arrow, and select Back to menu.
