I have both VideoStudio 8 and DVD MovieFactory 4 installed (I know these are old versions but they work fine for me).
I recently installed VideoStudio 11 trial version and since when I have a problem with both VS8 and DMF4:
When I play a created DVD it crashes when I try to move to a different time on DVD player's position bar with the mouse. Otherwise it plays fine and there is no problem with moving between chapters.
Since then I uninstalled VS11 trial, uninstalled and reinstalled both VS8 and DMF4 but the problem wasn't solved.
I tried playing older DVDs and they worked fine so where is no problem with the DVD player (I use Media Player Classic).
DVD player crashes when moving on position bar.
ronial77
First, it could be a physical problem with the DVD. You might have a scratched disc, or you may have purchased a batch of bad (or flaky) blanks. A simple way to check for this is to copy the VIDEO_TS folder from the DVD to a temporary folder on your hard drive (using Windows Explorer). If this fails, you've got a bad or damaged DVD.
Physical problems can be somewhat tricky, because the operating system has error correction and DVD player software/firmware has error correction & error hiding. Nero offers a FREE program called Nero CD-DVD Speed that can help detect errors that are being corrected.
Second, the MPEG could be corrupted. This can happen if you feed Video Studio a corrupted MPEG and then check the Do Not convert box, and it can sometimes happen if you edit an MPEG. (If you feed Video Studio a corrupt MPEG and allow Video Studio to re-code it, you might end-up with different problems.) It should NOT happen if you let Video Studio (or Movie Factory) create a fresh MPEG from an AVI/DV file.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
ronial77
ronial77
You know that .ifo files are not video files; just InFOrmation files about the structure of the DVD...?
That being said, it could indeed be a problem. There is a small freeware program called FixVTS which may be able to help you. You can download it from here: www.videohelp.com/tools/FixVTS Make sure you read the instructions, though it is essentially very easy to use.
ronial77
