Sound in Clip but not in Project view (again)
lexel
Post by lexel »
There are a number of problems in this web board similar to mine: when I preview in Clip mode the sound is OK, when I preview in Project mode the sound stops after two minutes (regardless what clip is displayed). All given solutions do not apply in my case.
I use an "Easylite PCI TV and FM Card" to capture old VHS videotapes via the S-VHS entry. I used the provided software TVR 3.21 and saved the captured files as MPEG and as AVI. Afterwards I also used VS8 software to capture files and save them as AVI: AVI File - OpenDML, Audio compression PCM, 32kHz, 16 bit, stereo. In all cases the problem is the same: previewing in Clip mode the sound of every clip is OK (poor but OK), previewing in Project mode results in two minutes of sound and silence thereafter. A video file created in Share has the same problem.
I 'm not a technical person, but I made dozens of DV-tapes and DVD's (and one SVCD) using VS versions 6 and 8 (much more stable than version 6). The source - in most cases - was a Canon MV200 digital Video Camcorder.
It puzzles me most that there is sound for a few minutes, but then is seems to be turned off.
Post by Black Lab »
I do remember this problem in the past, probably with, as you say, v8. However, I don't recall if there ever was a definitive solution. I don't remember this problem coming up in versions since, so maybe that is the solution. :wink:
What happens if you split the audio?
lexel
Post by lexel »
Thanks for your reaction!
Black Lab wrote: What happens if you split the audio?
Same thing: large file, only first minutes sound then silence, some files no sound at all.
Post by Black Lab »
If you've had no previous problems with footage from your DV camcorder, and now you are having problems with footage from your PCI TV card, I would be leaning to that as the problem.
Does your DV cam support pass-thru? If not, since you are trying to capture VHS, why not connect your VHS player to your camcorder and record to tape, then transfer to your PC. Since the source is VHS I don't think you'll see much quality loss.
Black Lab wrote:I do remember this problem in the past, probably with, as you say, v8. However, I don't recall if there ever was a definitive solution. I don't remember this problem coming up in versions since, so maybe that is the solution. :wink:
You can try Jeffs suggestion by downloading the 30 day free trial.
autotech
Post by autotech »
I got the same problem.
Import and edit 3 or 4 .avi files and all seems well, then when I go to file project playback after about 2 minutes NO sound.
Sometimes it will come back for a few minutes then disappear.
Help Please as I am clueless.
BTW I am using the vs11plus trial version with only 3 days left.
lexel
Problem solved using V11 (trial version)
Post by lexel »
Sorry for this very late reaction.
The problem, losing audio when capturing from VHS, was solved, as suggested, using version 11. :D
To be honest: since I captured all VHS tapes I wanted to, I did not upgrade to VideoStudeo 11.
I do not need seven layers of overlay nor Chinese characters.
I would have liked better quality Titles, apart from that I am quit satisfied using version 8.
