It's unable to access audio codec driver
Locked
jarekhanzelka
Post by jarekhanzelka »
I cut piece of a video and when I try to save trimmed video, it says, that its unable to access audio codec driver. What can I do with it?
Last edited by jarekhanzelka on Mon Aug 13, 2007 11:20 am, edited 1 time in total.
jarekhanzelka
seven people saw this topic but none of them replied. Why? is the question so dumb or what? And if it is, does it really matter? I really need to cut the video in those parts and save them! So please, help me!
Re: ?
jarekhanzelka wrote:seven people saw this topic but none of them replied. Why? is the question so dumb or what? And if it is, does it really matter? I really need to cut the video in those parts and save them! So please, help me!
Apparently those 7 people did not have solution.. :shock: The reason may be because you don't provide any more information as to what audio codec? Is it MP3 (basically an MPEG2 minus the video), Lame, Dolby, PCM, MPEG audio Layer 2 ???
Please complete your System Information in your profile. Clicking on this button -->Image will take you to a short tutorial, explaining how to find and complete that information. This way it will always be available, and will save you from retyping it in the future.
Please read this post, and return with as much of the information as possible.
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
jarekhanzelka
info was added
the video size I'm trying to work with is 701 MB, the file format is AVI, it does no problem to open the actual vid, it does no problem tu cut the piece (original vid has 01:10:48 and the piece I cut has 00:06:53) and then I try to save it as trimmed video, and the mistake above pops up. Now let me tell you, what I need to do with the original vid. I just need to make few videos, that will be long under 10 minutes, which means I will do about 10 cuts in original vid. That's all I can describe. Thanks
The container is AVI, which I'd guess contains a DivX or Xvid file, correct?
With your video clip in the Library or on the Timeline, right-click, select and post back the Properties here.
You have provided some more information, however look at the links I provided. That information is what we really need. Without it, I can guess that your AVI is either uncompressed (not since uncompressed AVI eats up 65 gig per hour of video), DV (probably not, uses 13 gig per hour), now we're getting down to DivX, Xvid, MOV, MPEG4.
Your error seems to be saying that it needs a specific audio codec, that you don't seem to have installed on your system. So we need to determine what audio codec is being used in your video clip.
jarekhanzelka
the video properties
ok, so here are the video properties:
File format: Microsoft AVI files -- OpenDML
File size: 718 176 KB
Frame rate: 25.000 frames/sec
Duration: 4202.640 seconds
Data rate: 170.14 kbps
VIDEO
Compression: DivX® 6.6.1 Codec (1 Logical CPU)
Attributes: 24 bits, 640 x 272
Total frames: 105 066 frame(s)
AUDIO
Compression: AC-3 ACM Codec
Attributes: 48,000 kHz
Total samples: 201 726 720 samples
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
You also don't say which exact version of Video Studio you are using. If it is before version 10+, or else is a trial or SE limited version, then it does not come with the Dolby codec you need.
You also need to be aware that if you use the decompressor which Clevo has just directed you to, you should at least be able to save your trimmed video. But after that, when you edit it further and go to produce your final DVD, you will not be able to encode out again in the Dolby format. That decompressor only works in one direction (in) and not out... So you will need to choose one of the other audio formats compatible with DVDs. Since you appear to come from Poland, I would say you use PAL and so you can choose either LPCM audio or mpeg layer 2 audio as the output format.
jarekhanzelka
Actually, I come from Czech Republic and I own full version 10.
however, I don't understand this. I installed the AC3 ACM Decompressor, rebooted system, tried to save trimmed video but it still says the same. It still is unable to access the audio codec.
Re: ?
This highlights the need to choose a topic title carefully.
Perhaps those 7 people thought you were offering them a link to a free audio codec rather than being confronted with a question about a problem with one.
You haven't told us the SOURCE of your DivX avi. I strongly suspect you have downloaded this off the internet.
Please Read This Before posting wrote:SUBJECT: Please use a subject that describes your exact problem instead of making us guess what's in your post.
Sorry if you this sounds like I am telling you off - I am not.
You can alter the title by using the [Edit] button on your first post.
The purpose of providing a meaningful title is this.
There are a number of members on the forum who try and help troubleshoot problems - myself included. In the early days of the user forum it was not too difficult to be able to read all of the posts submitted since the last time I (or one of the other troubleshooters) had logged on.
On the Forum Home page at the top right is a link
[view posts since last visit] In the forums early days this would perhaps range between 10-30 posts. Today however the board has grown in popularity and more products are now catered for including the former Intervideo products before the merger with Ulead.
There have been days when I have logged on to find over 70 new posts since my last visit. It is of course impossible to read each and every one of them and so it is necessary to look at the titles to pick out posts where I feel I am able to offer some worthwhile input.
if you are viewing perhaps the VideoStudio forum and a post is entitled
"VideoStudio" - it doesn't really give you a clue, similarly in the PhotoImpact forum a post entitled [PhotoImpact] is equally as meaningless.
Giving a post a suitable title is a means of helping us to help you.
jarekhanzelka
I don't know, if it's downloaded from the internet, it's been on CD for last five years at least. It's the movie Matrix(1999) that I own on DVD and two CDs. Now I'm working with those two CDs. My brother brought it home years ago, now I try to work with it.
Sorry but that is a commercially produced Video which is copyright protected.
Locked
