DV to DVD Tutorial
DV to DVD Tutorial
I couldn't find a DV to DVD Tutorial for VS10+ and I'm sure you have one. Please point to the correct spot. I just need to know some basics like:
Which is the better quality SP 60 or LP 90? If it parallels VHS tapes, it's the former
Quality is best vs standard, right?
I'm recalling all of this because my program is doing a DV to DVD as I write this so I apologize if my terms aren't quite right
Thank you
Thank you
Richard
- ram: 2 GB
- sound_card: Intel GMA 950
We have.....
From Camcorder to DVD with VideoStudio
VideoStudio 9 training videos:
http://www.veoh.com/series/vs9
VideoStudio 10 training videos:
http://www.veoh.com/series/vs10
Plus of course our Video Tutorials Section
- ram: 2 GB
Please view:
Suggested Workflow
Suggested Workflow
We have created a video tutorial that will guide you in the right direction.
http://takeoneflix.com/ulead-videostudi ... -chapters/
Hope this helps
Edit by sjj1805 - Web Board Administrator 26 Feb 2009.
When this post was created the video tutorials mentioned were all free.
That has now changed and members are advised that they have to be purchased. I must point out that these links are only provided for the purpose of convenience to our members. Neither Corel, the Forum Management or myself endorse any of the products listed and I/We have no associations with the vendors of any software listed below. I/We do not guarantee the quality of any of these products or their compatibility with the Corel products they are designed to work with. I/We will not enter into any negotiations between Members and the Company providing these tutorials.
Hope this helps
Neel Mehta
[size=117][color=red]Many useful VideoStudio and PhotoImpact tutorials can be found at
[/color][url]http://seeitdoit.tv[/url][/size]
At this point it feels like overkill for what I want to do. With the forum's input, I've had real good results making DVDs of videos plus stills and I am trying to find a simple way of reproducing the DV tape for archiving purposes.
So, using what I have already learned, I just:
(1) Went into the editor
(2) Captured the entire tape and set my project properties to AVI
(3) Created the movie file by using the custom option and save it as an AVI file
(4) Burn the DVD
Won't that work OK? The only other question I have is, if you agree with the above method, can I use the archived DVD to make future projects?
(4) Burn the DVD
Richard
You are missing a step after 3. Using 3, you will have a DV/AVI which you can export back to your camera mini DV cassette for archiving. However, you should not be using this edited DV/AVI for burning directly to DVD as you imply by your current step 4.
Instead, I would add a new step 3a: Use Share > Create Video File > DVD to convert the DV/AVI edited file to DVD-compliant mpeg-2. Then your step 4. would follow that, but with the reminder "Burn the DVD *using the new mpeg-2*".
EDIT: Or am I misunderstanding something here?
When you finalise your AVI file and then in the next step burn the DVD, are you talking about a video DVD, or simply an archive/data DVD? If the latter, then if your AVI project is one hour, it will be around 13 GB in size, so you will in fact need probably 3 DVDs to archive it (if using single layer DVDs).
You will certainly be able to use AVI archived this way for later projects. Mind you, you could also use the footage of a *video* DVD (i.e. with the AVI already converted to DVD-compliant mpeg-2) in later projects too, using the Insert DVD/DVD-VR function. But of course, you then involve the loss of quality inherent in re-rendering mpeg-2.
- ram: 2 GB
You might find this link of interest:RTR1944 wrote:........What about the question about using it for future projects (although I think that is very unlikely) assuming the original DV tapes are no longer usable?
Preserving your recordings
Another observation - you refer to avi. This is a generic term for a variety of formats considered non lossy. Your average mini DV camcorder records in DV (avi) = 13GB per hour. In addition to this you have amongst the dozens available:
Uncompressed - 65 GB per hour (Gigabytes)
DivX / Xvid / MPEG4 - 700 MB per hour (Megabytes)
You're right. I think I did the video DVD but I probably want the archive/data DVD because I would want the flexibility and I don't want to lose the quality. I can just archive them on DL DVD's if space is an issue.
So, could you walk me through the steps to accomplish the archive/data DVD?
I'm sorry but I am not an advanced "techie" and I have be spoon fed! I literally copied some of jcjunter's thoughts into a Word document and followed them "to the letter" to get my results that I mentioned before
Richard
1. Capture and edit your DV/AVI.
2. Ascertain how big the file is and how many, and what type, of blank DVD you will archive the video on.
3. Cut video into appropriate sized bits which will fit on a DVD. Then go to Share > Create Video File > DV to produce a new DV of each edited and cut video.
4. Close Video Studio at this point and forget about it for the rest of the operation.
5. Open Nero or similar suite of programs. Choose 'Burn Data DVD' or equivalent command in the program you use. (You cannot use Video Studio to burn a data/archive disc.)
6. Browse to where you have stored your edited DV files. Insert in the burning program and Burn.
7. Note that as archive files, they will not play in a stand-alone DVD player. You access them on a computer as you would any other data file on a disc.
As promised, I tried your suggestion and it worked great! You are right re: size of file! My 5 minute experiment ended up being 1.06 GB which equates to 2 DL DVD's per 60 minutes if I wanted to archive the entire original video which I'll probably do. To me, it's worth the expense to archive and have the flexibility to use it in another project should I decide to do that.
I may seem a bit anal, but when you have video of a trip of a lifetime, I want the archiving done on something more stable than a DV tape and more dependable than an external hard drive. And, for now, I'll have them on all three!
Thanks again for your help
Richard
For ultimate safety, that's probably your best bet. Just don't forget that as technology changes, so must your backups. Who knows, in a few years you may not be able to find a camera to play your tapes, or DVD players may become obsolete.I want the archiving done on something more stable than a DV tape and more dependable than an external hard drive. And, for now, I'll have them on all three!
Also don't forget to check the backups from time to time, and if they show any signs of problems, make sure you backup the backups.
Jeff
Dentler's Dog Training, LLC
