Indulge a drowning man
ritasfrank
Post by ritasfrank »
Hello everyone,
I am a complete novice( That's English, for not too bright!)and can hardly tell my Avi, from my crossfade,I am struggling with abbreviations acronyms etc.,but my problem is -I am using VS10+- apparently when I save, I am not in fact Saving, just putting my work on hold,It seems that the work is only realy 'Saved' if I make a video file, saved in this context meaning I can leave it on my hard drive, transfer it to an external hard drive, or make a DVD, have I got this right? Any kind words would be gratefully received
Many thanks FRANK
When all else fails, Hug your Teddy Bear!
DVDDoug
Moderator
Post by DVDDoug »
You are correct. You are "saving" the project "instructions".
Go the the Share tab to create a video file.
This is the nature of "non-linear editing". When you apply your edits, the original file is not edited, but a new-edited file is created.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
ritasfrank
Many thanks Doug,
I am sure an avalanche of questions will follow , once I get my head around the concepts
Cheers FRANK
If, for instance, you are wanting to produce a DVD, then after you do your editing, you select Share > Create Video File > DVD and this will convert your project to a DVD-compatible mpeg-2.
When you select Share > Create Video File, you will see a drop down menu which will give you an idea of the various formats you can 'save' (i.e. convert/share) to. And when you get more confident, you will take advantage of the Custom choice down at the bottom, and make your own templates...
ritasfrank
Bless you Ken,
It's a steep learning curve,VS10+ has everything I could ever want, I'm sure, It is just a matter of time and practice, with visits to the 'High Priests' here on the Forum!
Cheers FRANk
