Hi all,
I'm running Vista 32 bit and DVD movie Factory 6 plus
When it got to burn a 8.5gb dvd, I got this error message
I read up about it and found out it could be drive or media, well drive is a brand new one and I changed DVD 8.5gb size and same thing ahppened again.
What else could I check?
Phil
DVD movie Factory 6 plus Power failure error
Are you saying it works OK with single-layer discs?
Whenever you start a new burn, the drive performs a little test-burn to adjust the laser power. When it fails, it's usually called a "power calibration error". I think this what's happening to you.
You could try a different brand of blank disc, or perhaps just a different "batch". (Experimenting/troubleshooting with dual layer discs can get expensive!
I believe the power calibration process is controlled at the firmware/driver level, so I don't think it has anything to do with Movie Factory. But, you can try some other burning software* to make sure it's not a Movie Factory problem. (Your burner probably came with it's own software if you don't have some already.)
If you have "drag & drop" burning software on your computer, it can take-over your drive and prevent Movie Factory from burning. (I wouldn't expect this to cause a "power failure", but it's somehting to consider.)
If it doesn't work with different discs and different software, then the new burner is probably bad.
* There is a way to create a copy of the DVD on your hard drive, so that you can burn multiple copies or use different burning software:
Un-check the box that says "Create to Disc," and check the box that says "Create DVD Folders".
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
What Dual-Layer Media are you using?
It took me quite a few burns to find the correct media that would work properly in my dvd burner. I can burn most of the dvd-r / dvd+r disks single layer but burning dual-layer is a different ball game with my burner. Seems like these dvd burners are very picky when it comes to dual-layer burning.
remind
Power Calibration error
Hi and thanks for the replies.
Yes that is the error.
It is doing it on Duel Layer TDK brand. 8.5gb selected.
I'll try it with a 4.7 disc and see.
Never had this problem on previous PC usinf same version of DVD movie Factory
I did get a dual layer to burn okay using Windows DVD maker that comes with Vista pre installed although it would not play back on my dvd player connected to TV, yet a 4.7gb one did. Sounds like TDK duel layer's are fussy or my dvd burner and dvd player connected to TV is.
Now I think about it last year Ulead release for XP a patch for duel layer burning which I still have, does anyone know if that was XP only?
I'll see if it installs in Vista 32bit, as now I recall that solved a similar problem
Player connect to tv is a Panasonic dvd recorder, and I must admit I would never buy one again, even though I have run a dvd cleaner disc in it, it doesn't read any ram discs I put in it, even brand new Panasonic ones. But that is for another topic and forum.
I use Alcohol for the other point you made DVD DOUG
Previous System was a Dimension 9150 and this is a XPS 710, both Dell's
I'll get myself another brand of Duel layer and see what happens
PM
PM
Sure sounds like your panasonic dvd recorder needs to be repaired. My panasonic dvd recorders work great. Don't know how old your panasonic unit is but mine are older and cannot play +R format unless I change the "Booktype" to Dvd-Rom. So burning straight dual-layer dvd+r dl dvd's don't work in my pana players. I use Nero to burn the dvd's which can also change the "BookType".Player connect to tv is a Panasonic dvd recorder, and I must admit I would never buy one again, even though I have run a dvd cleaner disc in it, it doesn't read any ram discs I put in it, even brand new Panasonic ones. But that is for another topic and forum.
- ram: 2 GB
- sound_card: Intel GMA 950
Check the Panasonic website for updated firmware for your DVD burner.
Even though its 'New' you don't know how long its been in the shop/warehouse.
I once had to replace my DVD Burner for another from the same shop and it was the same make but the model was slightly different. I knew my system was OK because until the original burner developed a fault (foreign object got stuck inside) I had no problems burning discs.
When I came to use the 'new' burner (bought from a famous nationwide High Street Store) I had problems burning. I checked my manufacturers website and sure enough there was some updated firmware. Installed it and had no problems thereafter.
remind
dvd burening issues
The Panasonic is a dvd recorder that connects to a TV, not the computer version.
So can one tte firmware onto it how would you upload the firmware to the unit?
PM
PM
- ram: 2 GB
Re: DVD movie Factory 6 plus Power failure error
remind wrote:Hi all,
When it got to burn a 8.5gb dvd, I got this error message......
2 Problems:
1 - Your dvd burner in the computer..
2 - Your playback device (dvd player).
BUT, this is truly jumping the gun. ALL Panasonic dvd recorders can record & playback to dvd-ram disks that are compatible with the recorder. Maybe you are using 3X or 5X ram disks that aren't compatible?. I don't understand when you say won't playback dvd ramdisks. Playback what? You can't burn a video based dvd-ramdisk on the computer without going through alot of work preping the ramdisk (formmating in udf format), then writing to it in the -VR format.
Sorry, you don't provide enough information.
Follow panasonic's instructions: Download latest firmware and put on a cd. Insert cd into pana recorder & turn on.The Panasonic is a dvd recorder that connects to a TV, not the computer version.
