Help with the texture
pogee
Post by pogee »
Can help somebody?
I want to place this image to the upper label.
c3d+image
Other question:
It is possible trasparent object (like the bottle) in the Cool 3D?
Thanx
mathis
Re: Help with the texture-Other Question
Post by mathis »
Hi, pogee,
Okay, I got your bottle. To make it transparent like the bottle in Cool 3D, just select the bottle (Graphic Object 3) and under Object Style, choose, Material Gallery, then Glass, and choose the color you want.
While I was able to get the image around the upper label, I'm unable to make it fit so it's visible. I was able to stick it on the actual bottle, but not on the label. Hopefully, someone else here will be able to help you with that function.
pogee wrote:Can help somebody?
c3d+image
Other question:
Thanx
klowther
Post by klowther »
Hi pogee,
Here is what I came up with:
beer.zip
I cheated a little bit and replaced the label object that you had with a lathe object. Have a look.
Hope that helps.
- Ken
P.S. My solution will only work with Cool3d Production Studio.
