i am using uvs 11 and i am very disappointed with this software it works so slow
I have to capture an vhs and i have no analog port so i am using my dv camera to do that when i was using uvs 9 it was very easy i just connect my vcr to my dv camera and my camera to my computer and it woks fine i just open uvs 9 go to capture section and start capture in any format but now i am using uvs 11 and now when i try to capture from that it fails uvs does not capture the video i am very disappointed i uninstall the uvs 11 and use uvs 9
u lead video studio 11 is very bad
Yes, v11 apparently has a bug that prevents the capture of analog video.
See http://phpbb.ulead.com.tw/EN/viewtopic.php?t=25120 for more info.
Jeff
Dentler's Dog Training, LLC
Welcome to the forums,
There is a bug with A-D (anlog-digital) capturing. In fact there is a problem with capturing analog period. Corel in it's infinite (or maybe that should be finite) wisdom replaced the Direct Show capture plug-in with their own IVI plug-in. It will not allow capturing analog video. Several of us have tested this using the same method as you, and it fails.
I have reported this some time ago to them, to specific contacts within Corel. They agreed that it is a bug and will be issuing a fix to it. When is anyone's guess. Until then, at least you, like several of us dedicated Ulead user's have an earlier version that you can use to capture. I however use a free DV capture utility called WinDV. All you need is a firewire port, and DV source. It captures only to DV.
I'm pretty sure this free utility will work to capture from your dv cam.
Then just insert the dv.avi file into the timline of VS.
WinDV is the name of the program.
http://windv.mourek.cz/
jessiecat
Problem with Capturing
We used to be able to capture video but now everytime we try it tells us "Capture Module Initialization failed" and "Capture manager Intialization failed" and then the Capture Video Icon won't appear. Is this related to analog problem you mentioned - is there a setting on the camera? I repaired the program, made changes to the settings, etc. Any ideas?
Jessiecat
Jessiecat
