Applying text effects from easy palette
BuZZarD
Post by BuZZarD »
I type a word, then try and add any of the text effect options from easy pallete and I get an error:
Unable to apply the selected thumbnail's properties to the image.
I've managed it before but only us PI12 once a blue moon.
MrA
Post by MrA »
It's in the help file.. I just did it.. but, from the menu bar at the top while entering in the text.. and it worked ok from the galleries..
holytomato
Re: Applying text effects from easy palette
Post by holytomato »
Go to File > Image Properties to check if you are working on an image mode that is other than RGB True Color 24-bit. Text effects will not be applied if you are not working with True Color.
