I have then done the following (copied from another one of my posts answered by Ron and Ken)
Did this bit fine and now have a MPEG2 file on my PC of 1.5GB ( lots of photos).go to the Share>Create Video File step, and choose NTSC (or PAL, depending on where you're located) DVD. This will render your project to a DVD Compliant MPEG2 video file. DVD(SD) specs require that the video files be in the MPEG2 format, not DV or AVI. This step may take several hours, depending on the complexity of your project and your computer.
This next bit is where it goes wrong. I quote the following from the same previous post
I click on SHARE and then Create Disk, which opens a window. I then click "Add video file" and select my 1.5GB MPEG2 file and it adds it to the bottom strip of this window but none of the controls work under what I would call the preview window, they are all dimmed out. I presume my MPEG2 should play in this window but it is black/blank.Once your DVD Compliant MPEG2 file is completed, go to the File menu and select New Project. This will clear the timeline. Do Not place anything in the timeline. Go back to the Share Step, and this time select Create Disk. This will open the Burn Module.
If I ignore this and carry on i.e and just click NEXT I get the screen for inserting menues but even though I select different menues, when I click PREVIEW it takes me to a screen with a remote control and when I click the play button it just seems to flicker, ie it takes about a second and flickers as if it played the menu or something in 1 second although all I actually see is the screen staying black. The menu was set to 20 seconds under edit so I cannot see what is going wrong here.
What I am attempting to do is this and I quote again
but as you see I am stuck with the process above just after I select creat disk in share.Now insert the DVD Compliant MPEG2 you just created. Continue on building your menus, adding chapters ect., until the final step, which is where you burn the disk, Create DVD Folders, or a Disk Image file. Since you have Nero, you can at this point uncheck the Burn to Disk option, and check the Create DVD Folders. This is what's commonly called burning to your Hard Drive.
Can somebody help me please? Any help appreciated
