VS8 should install and run fine on WinXP Home, as I currently have it installed on my machine. I'm running XP Home, SP2, with all the current updates.
What you describe should be a Full Boxed version, and it is not given away. The
SE labeled versions however are. If you were able to register it with Corel (Ulead), then it should be legitimate, and not a pirated copy.
Try clearing your
Temp folder before installing. It can be found here: C:\Documents and Settings\
UserName\Local Settings\
Temp. Do not delete the Temp folder, just all the files in that folder. You will also need to be able to see Hidden Files/Folders.
To view Hidden Files and Folders, in Windows Explorer click on
Tools menu, select
Folder Options from the menu. In the Folder Options Dialog click on the
View tab, scroll down to
Hidden Files and Folders, and check the radial beside
Show Hidden Files and Folders.
What (if any) is the error message you are getting? Is it a
CRC Error, Cyclic Redundacy Check ? If so that could be due to the disc being bad, or your CD reader, and possibly your RAM failing. I have experienced this type of error, and it was my RAM failing. It was difficult to trace to that. I used the free utility
Memtest86. After running several passes, it found where one of my RAM sticks was failing. After replacing it, I no longer have the CRC errors, while trying to install programs.
